Old 05-14-2004, 01:37 PM
Racincc85's Avatar
Racincc85 Racincc85 is offline
Send a message via AIM to Racincc85
A/C problem
I've got a 1990 buick lesabre. I retrofitted the A/C system to the R134a refrigerant after fixing a leak. I removed the compressor, drained the oil, put in r134a compatable oil, replaced the receiver/dryer and charged with 80% of the r12 capacity. I'm only getting lukewarm air from the vents, about 52 degrees or so. I like ice cold a/c; is there anything i can do to improve the cooling, or could i have messed something up that toasted the compressor? The high side was reading 200 psi and the low side 30psi at 80 degrees ambient temp. When i charged the system, i inverted the refrigerant cans (sent it in as a liquid instead of a gas to the low side) to get it to charge faster? could this have damaged something? thnx for the help
Old 05-14-2004, 08:37 PM
Flatrater's Avatar
Flatrater Flatrater is offline
Main GM Guy
Re: A/C problem
R-134a is not as cold as R-12. A 30 degree temp drop on R-134a is a good temp. 52 sounds pretty good.
Shop Foreman Buick Pontiac and GMC dealership
ASE Master Tech
ASE Advanced L1
GM Master tech
Licensed Aviation mechanic
