Old 05-14-2004, 01:16 PM
sovietrooski's Avatar
sovietrooski sovietrooski is offline
Send a message via AIM to sovietrooski
supercharger
is this supercharger worth it?
http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WDVW
On a traffic light green means go and yellow means yield, but on a banana it's just the opposite. Green means hold on, yellow means go ahead, and red means where the fuck did you get that banana at...?
Sometimes I wave to people I don't know. It is very dangerous to wave to people you don't know, because what if they don't have a hand? They'll think you're cocky. "Look what I got motherfucker, this thing is useful...I'm gonna go pick something up"
-Mitch Hedberg
Old 05-14-2004, 01:20 PM
CarSuperfreak's Avatar
CarSuperfreak CarSuperfreak is offline
Send a message via AIM to CarSuperfreak
Re: supercharger
well.....lol
a supercharger is defined as being belt driven, so first of all, this is a vacuum-powered turbo. Id find out if you could find anyone else who has used this, and ask their opinion, as well as ask the seller what kind of boost you will be getting as well.
Old 05-14-2004, 01:42 PM
kilroypr's Avatar
kilroypr kilroypr is offline
Send a message via MSN to kilroypr Send a message via Yahoo to kilroypr
Re: supercharger
That is not a supercharger. If I were you I would rather not buy stuff like that without knowing the chamber and spindle conditions. You can CSC your car, check http://www.intense-racing.com or http://www.zzperformance.com and check for the CSC(Centrifugal Superchargers) that can be adapted to 3.1, 3.4 and almost everything out there.
Old 05-14-2004, 01:49 PM
Re: supercharger
(or if you already have the 3800, get one of tried and tested OEM superchargers)
Old 05-14-2004, 02:07 PM
kilroypr's Avatar
Re: supercharger
CarSuper, the problem installing the Eaton Roots SC on top of the 3800 is that the NA 3800 version could have flat compression pistons and the SC 3800 has domed pistons and other internal components could be different. The roots sc is harsher on the engine and tranny than the Centrifugal since the centrifugal boost is applied mostly at the high rpm range wereas the root sc applies boost from the low RPM range all the way up the red line.
You can bolt the Eaton Roots M90 or M112 on but the PCM has to be changed too.
THe CSC tops boost doest not reach 6psi wereas the Eaton root SC could develop more than 6psi and that would affect timing, MAP, MAF readings and the KR has to be prevented too.
Since the ignition and spark plugs are set up for a non SC vehicle these among alot of other stuff need to change to prevent or lower KR and other bad things that could harm your engine.
Old 05-14-2004, 02:13 PM
Re: supercharger
im not saying its a good idea to begin with, but its btter than the non-supercharger thing he listed on ebay. personally, if he were to go the OEM supercharger route, i totally agree with you, that you basically gotta start from scratch.
Old 05-14-2004, 03:14 PM
kilroypr's Avatar
Re: supercharger
Exactly . But if it is too expensive the CSC is an alternative
Old 05-14-2004, 04:07 PM
sonhasteg sonhasteg is offline
The heads are different on the SC 3800 too. The fuel injectors are located in the heads. The NA 3800 has the fuel injectors in the intake manifold. A lot of GT/SE owners who have done the swap claim it will cost the same to buy & swap in an SC motor in as it would to change everything necessary to make the NA motor except the SC...but I don't know that for sure.
Old 05-14-2004, 04:09 PM
kilroypr's Avatar
Re: supercharger
Check http://www.l67swap.com
Old 05-14-2004, 05:41 PM
so should i get the OEM supercharger? ive got a 98 gt 3800
-Mitch Hedberg
Old 05-14-2004, 05:43 PM
Ripn12s's Avatar
Ripn12s Ripn12s is offline
Send a message via AIM to Ripn12s
Re: supercharger
No u should find a L67/4t65eHD and replace the L36
