Old 05-14-2004, 10:06 AM
95GSTRaCeR 95GSTRaCeR is offline
95 cas on a 98
I own a 95 gst and somehow I blew three holes(big ones) in the block and about an 8 inch crack on the block. So I bought an engine out of a 98 to replace mine. I knew that I was going to have to splice the cas wiring into my 95 harness, but the guy didnt cut the cas wires off with the sensor, on top of that the sensor itself is broke off. I was looking at the two engines and I noticed that the 95 sensor can bolt onto the 98. So my question is if I swap the cam pully and the sensor from my 95 onto the 98, will it work? Thanks for any input.
Old 05-14-2004, 10:23 AM
EclipseRST's Avatar
EclipseRST EclipseRST is offline
Banned
Send a message via AIM to EclipseRST Send a message via MSN to EclipseRST Send a message via Yahoo to EclipseRST
yes it will... i had to do this when i went down to Kansas to swap heads on 95eclipse_gsx's car... my head was from a 97 his was a 95 so i just bolted it on and plut it in! works just fine...
Old 05-14-2004, 10:38 AM
Re: 95 cas on a 98
Cool, thanks for the help, now I just have to try to break that pully bolt loose...
Old 05-14-2004, 10:46 AM
EclipseRST's Avatar
Banned
stick a screwdriver between the pullies so it wont move then bust that bolt loose!
