| Off-Topic Talk about anything other than cars. |
Whistling noise from intake???
My spyder has the following mods....1g BOV, Injen Intake, DP and Hi-Flow cat. If you are sitting still, or even moving, when you let off the gas there is a whistling noise coming from the intake. Sounds kind of like the factory BOV when the car was stock, except this noise is longer and not as high pitched. It only does it at certain rpm's, namely right around 2000. I cleaned it the other day and it sounded a little better but not much of a change at all. Any Ideas????
By the way...it didn't do this for the first year I had it. |
don't know what to tell ya!.. you're fucked!!!
LOL>... j/k
06 Charger SRT-8 black. |
Re: Whistling noise from intake???
Check for a leak somewhere
For Sale 98 Eclipse GS, 5 spd |
Well it's actually comming out of the filter not the piping.
Does the filter have a rip or hole in it?
that sounds like a pretty damn big HOLE!! LOL.. maybe you just need a new filter. what kinda filter do you have. i know that K&N get filled up with dirt quick.
k&n are designed to use the "dirt" as part of the filtering media i dont have the site but look up k&n filters and read about them
-1stGenRocks- 95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's plans: bastard 20g, water/meth injection NO FMIC |
so dirtier the better?
If i get this right the dirter the more filtration, but then less flow
i heard the K&N has the best filtration while the HKS which is what i use has the best flow.
No....the last time I cleaned it I didn't see a rip or hole. It is only about 2 years old and I thought they were supposed to last for longer than that. It's the filter that comes with the Injen Intake (I don't know if it's made by K&N or not).
i'd say get a new filter... and i'm not sure if that HKS one your using Rocket is foam or not, if it is watch it!!! i just seen one that started to disinagrate cause it got a little moisture on it and the motor sucked the whole foam piece up into the head! wasnt pretty, good thing it was a honduh!!!
its probably a imitation k&n. is it like folded screens with red/gray crap in the middle?
It's this one
http://www.extrememotorsports.com/g2cat/injen-l.jpg So RST...you think I should replace it? Shouldn't it last longer than that? |
well you said you've had it for 2 years... thats pushin it i think... i change mine every other spring before i take it out of storage!
