Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 05-14-2004, 12:59 AM
C-MAX95 C-MAX95 is offline
Need help code po400
i have a 95 maxima with 200600 miles on i keep getting the code p0400 (EGR Flow mailfunction) i cleaned the valve it self, then i reset the ecu, drove close to 500 miles, and the check engine light stil off so i thought that is it i got it, but tonight was leaving work the light came on i checked the the ecu and here i get the same code p0400 plus p0136 (o2 sensor ) bank1 sensor 2 which is the sensor gose in the cat converter.
need help with this please
thank you
Old 06-25-2004, 12:29 AM
habenero2002 habenero2002 is offline
Send a message via Yahoo to habenero2002
Re: Need help code po400
for p0400 you are going to have to remove the intake manifold and clean all the egr passages. for p0136 you need to replace the sensor
