Old 05-14-2004, 12:18 AM
Norkex's Avatar
Norkex Norkex is offline
Question Gas Mileage, and Octane...
With the price of gas on the rise, I was wondering if there was anything I could do to increase my gas mileage... Right now I'm getting 13-14 mpg, I do have a heavy foot, and was wondering if this is normal or not?
86 GT Hatchback. My mods include: removed air silencer box, K&N filter, underdrive pulley kit, mac shorty headers, and 3 chamber Flowmasters with pro dumps... (I'm guessing they're 3 chamber due to the lack of that deep sound other mustangs around these parts have.)
And, while I'm on the subject of gasoline, I was wondering what difference, if any, there would be in using a higher octane fuel with stock timing?
Thanks in advance for any advice/insight.
Old 05-14-2004, 09:03 AM
HiFlow5 0's Avatar
HiFlow5 0 HiFlow5 0 is offline
Stanger
Send a message via AIM to HiFlow5 0
Re: Gas Mileage, and Octane...
Unfortunately, many people assume that higher octane fuel is better for all engines, no matter what. This, as I'm sure you know, is absolutely false. Ultimately, the best octane for any vehicle is the lowest one you can run without detonation (pinging) occuring.
Running too high of an octane will ultimately make it necessary to continue using that octane.
Just to clarify, it's not the fuel that increases the performance, it's the fact that the timing has been advanced. The higher octane permits this to happen. Basically, the way it works is something like this:
Octane represents a fuel's stability. When you compress an air fuel mixture, it becomes quite unstable, and explosive. In fact, this is why diesel engines don't require spark plugs. They commonly have compression ratios of 22:1 (as opposed to a stock Mustang with 9:1), which makes the air/fuel mixture so explosively unstable that it ignites itself when the piston reaches TDC.
Octane, for all intents and purposes, is used to slow down, or control the burn rate. Modifications that increase performance, such as increased compression, or advanced ignition timing, will cause the mixture to become too unstable, and pre-ignition (aka: detonation, pinging) will occur. This is when the mixture fires on it's own, at the wrong time. Severe damage will occur if left untreated. Anyway, the only way to perform the mods that increase the power is to further slow down and control the burn rate of the air/fuel mixture, and the method used to do this is increased octane.
People often think of high octane fuel as being more flammable, and easier to explode, whereas that is actually the opposite of the truth. 110 octane race gas is much tougher to light than low grade 87 octane. BUT, because of that fact, it is the use of 110 octane fuel that permits the compression to be increased to 12:1 without melting the pistons.
On a side note, nitrous oxide works on a very similar principal. With nitrous, the power comes from the added oxygen. The problem has always been trying to find a way to add oxygen safely. As I'm sure you know, oxygen is EXTREMELY flammable, and if you were to try and add it straight to your engine, you would likely die, and not even be able to explain to people why it was you died. It was discovered that the nitrogen in the nitrous oxide was just enough to keep the oxygen from burning uncontrollably, thus permitting it to be used in a gasoline engine. In other words, the nitrogen is to nitrous oxide what the octane is to gasoline, except for the fact that octane is a calculation, and nitrogen is an actual element, but you get the idea.
Okay, back to the story...
Use of a fuel that has a higher octane than is required by the engine and the way it has been tuned will result in unburned deposits being created and left behind in the combustion chamber, and on top of the piston. Often referred to as carbon deposits, these cause the combustion chamber to become very unstable, for several reasons, all of which will ultimately require you to use a higher octane fuel to restore stability. Among the reasons, are increased compression (the deposits take up space, and actually increase the compression enough to make it unstable), retained heat (deposits retain heat at times when those surfaces shouldn't, increasing the likelyhood of pre-ignition), and the development of sharp edges (like sand under the waves, carbon deposits can be "shaped" by their environment, and can develop sharp edges, which act to the compressing mixture like a hat pin would to a balloon.
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex
-1999 Ford F150
Old 05-14-2004, 09:06 AM
HiFlow5 0's Avatar
Stanger
Wish I could take credit for that, but I can't. I came off the RHC site. Anyway, to get the most MPG out of your car, make sure your tires are filled propperly, you have a good alignment, and a fresh tune up with a clean air filter.
-2013 Ford Flex
-1999 Ford F150
Old 05-14-2004, 11:36 AM
SkylineUSA's Avatar
SkylineUSA SkylineUSA is offline
Send a message via AIM to SkylineUSA
Re: Re: Gas Mileage, and Octane...
I was getting ready to post that exact same thing, well sort of Its funny how big that misconception actually is. I believe that about 80% or greater believe that to be true.
R32 GTR w/351w .020 forged, 8.9:1, PTK T76, Turbosmart 40 BC & 45 WG, Tial 40 BV, AFR 205s 310/245, 228/228 550/550 114 Hydro, 1.7rr, Isky RLs, 4" HKS exhaust, ARC 30x16x4 IC, 8 point cage, C2 gauges, 2 step, C4 3200 stall w/ R Manual & Hurst Ratchet shifter, 17" Panasport G7s, CSU 750 & bonnet, Vic Jr intake, 3.63 gears, Corbeau Carrera seats, Custom wide body, Bomex side skirts and rear 1/4 caps, Tommy Kaira bumper.
Old 05-14-2004, 11:44 AM
burly94gt burly94gt is offline
Re: Re: Re: Gas Mileage, and Octane...
since we are on the gas mileage subject...how much will bigger heads and upper and lower w/ larger injectors affect gas mileage..for ex. a pair of performer w/ 24# injectors....just curious
Old 05-14-2004, 11:49 AM
SkylineUSA's Avatar
Should change very little if you drive the car the same way. That little go pedal on the right, that is where you lose your milage with the upgrades. If you stay out of it, it really will not effect your milage with those upgrades.
Old 05-14-2004, 12:06 PM
hah man thats gonna be tough...
Old 05-14-2004, 12:57 PM
Norkex's Avatar
Ah, that's what I thought, about the octane... And thanks for the advice on the mileage..
