Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '71-'87 Civic | CRX
Old 05-13-2004, 08:39 PM
RSLaser RSLaser is offline
Weird Question
How can i hot wire my Civic, i want to make sure it runs before i go buy a new ignition for it. I tried to drill it out but its been a pretty slow process.....any other ideas?
Thx Matt
Old 05-13-2004, 09:16 PM
cvcc_wagon's Avatar
cvcc_wagon cvcc_wagon is offline
Re: Weird Question
i think Hot rod Heistand may have an answer, he has set up a push button ignition in his civic racer. if it is the steering lock you are trying to get loose, all you can do is to remove the entire ignition, on my 83 it is bolted in with 2 headless bolts (the kind that twist off when they are torque down) to replace the ignition in my car they had to be drilled and a set of EZ-outs used to remove the bolts, i assume your will be similar, pull the plastic stuff off and have a look at what is holding it in.
~Attention! if you are thinking about a D16A1 swap for your Civic/CRX and don't know where to start go Here. Thanks.~
Old 05-14-2004, 08:06 PM
Hot rod Heistand Hot rod Heistand is offline
Re: Weird Question
Thank's buddy, I did the same thing to get past the steering lock but, Before I did that, I needed to make sure mine ran too, Before I went through the hassle of making a push button start, so I pryed the innerds out of the lock and turned it off and on with a screw driver. I think my main tools were Needle nose vice grips, screw drivers, and what ever else looked usefull. If you take it off the colum first then you have a heck of a time prying on the casing. Good luck.
Old 05-14-2004, 10:51 PM
thx for the help, before i got to it my brother had it and he broke off a slid breaker inside the ignition, so i have to drill around it, so its slow but hopefully ill get r done soon! ihave lots of mods in mind for it but i wanna make sure that it atleast runs.
