View Poll Results: tell me which one is the best for something new for 1986 chevy camaro
use old factory dashboard 1 20.00%
design dashboard with fiberglass 4 80.00%
make wood with dashboard 0 0%
make carpet dashboard design 0 0%
Voters: 5. You may not vote on this poll
Old 05-13-2004, 07:19 PM
FaStBuRnChEvY FaStBuRnChEvY is offline
Send a message via AIM to FaStBuRnChEvY Send a message via MSN to FaStBuRnChEvY Send a message via Yahoo to FaStBuRnChEvY
Question Fiberglass dashboard design help
hey ya'll i want to know your option about building and making fiberglass dashboard design and fiberglass stereo design will be look good on 1986 chevrolet camaro Z28 T-top. although that i will install 10 meters, 1 cd player, few switches, 2 sub 12 inches, 3 amps, 1 500uf Capitator, one equalizer, 8 speaker surrounder all 9 inches round speaker, 2 nos tanks, and some lighting system and electronic door opener and electronic window and trunk open and close. but 10 meters reading will be MPH (0-150), Tach (0-10,000 rpm), oil pressure, fuel, water temps, volts, amp, 2 nos reading level for 2 nos tank. tell me what you think. either old factury dashboard or making difference fiberglass design for street/strip car.
Old 05-13-2004, 08:06 PM
pfox_64 pfox_64 is offline
Hey if you ever get that done send me a pic. [email protected]
As for the poll i would go with the fiberglass it would look sweet if you put a lot of thought in to it, that is the same year camaro I bought. Fast as
F\/(k isn't it!
Old 05-13-2004, 08:52 PM
Dober89 Dober89 is offline
Re: Fiberglass dashboard design help
Thats a hell of alot or work to make your own dashboard. The only thing I would consider is upgrading to a 4th gen dashboard and maybe cutting some gauges in.
Old 05-13-2004, 10:10 PM
sykotic1 sykotic1 is offline
plated aluminum, big autometer guages, remove all accessories :-p
Old 05-13-2004, 10:12 PM
thanks but it would take a while to get it done by putting some woods in first and drill some hold where it needed like guage meters, switches, etc...
then to put all meter fit in hole and switches etc...and get it all wiring done to put whole wiring system to connect i mean everything when i buy painless wiring system for 600 dollar...then once of all it done then make sure everything working property to get motor runinng and meters running and stereo running perfectly then when everything is ok...i have to remove all meters and radio and etc...before to put foam on for make it look like balloon but some you dont need when you need fiberglass to hang it down but foam you only need to keep fiberglass up but it what i can do to make dashboard all shape up and make it look cool while i am done putting some foam and other dont then cut off some foam to shape it off and make it look good then get fiberglass supply that only cost more than 100 dollar to install and have to pt all fiberglass in then i have to do it 2 more time until it all done to get the fiberglass thick so it wont break. once it done so i have to sand it down to make it really smooth before i send this camaro to body paint shop to paint whole body inside the camaro then when it done so to install everything back in as racing seat radio carpet floor i mean everything so that is my plan....i would make it picture so whole engine transmission wire seat carpet everything is gone right now i mean it bare so to start making dashboard and do it inside before i send this camaro to body shop to paint it all black then paint shine navy blue fire on the outside front car.
