Old 05-13-2004, 07:02 PM
2ndb18's Avatar
2ndb18 2ndb18 is offline
Send a message via AIM to 2ndb18
check engine light...dang
The check engine light comes on when i go into second and just randomly goes on other times. what do i do
88 civic dx
Old 05-13-2004, 07:07 PM
slowCRXinPitt's Avatar
slowCRXinPitt slowCRXinPitt is offline
Pull back the carpet under the passengers side footwell. then remove the ecu cover. turn the engine on. there will be a little red light blinking. count the number of blinks and refer to a repair manual to diagnose the code.
Old 05-13-2004, 07:08 PM
Re: check engine light...dang
88-91 Civic ECU Trouble Codes
With the ignition on the ECU will display a single flashing light indicating the system is operating. When the ecu sets a trouble code,the check engine light will come on and the ecu stores the code in the memory. The trouble code will remain in the memory until voltage to the ecu is disconnected. Removing the hazard fuse in the main fuse panel for 10 seconds will reset all trouble codes. Reset the memory after repairs are made. Make sure the ignition is OFF when disconnecting the main fuse.
Code System
Code 1 (1 flash) Oxygen content
Code 3 or 5 Manifold absolute pressure
Code 4 (4 flashes) Crank angle sensor
Code 6 (6 flashes) Coolant temperature
Code 7 (7 flashes) Throttle angle
Code 8 (8 flashes) TDC position (top dead center) timing
Code 9 (9 flashes) No. 1 cylinder position (1.6L)
Code 10 (10 flashes) Intake air temperature
Code 12(12 flashes) No code 11 don't know why. Exhaust gas recirculation system
Code 13 (13 flashes) Atmospheric pressure
Code 14 (14 flashes) Electronic air control (EACV)
Code 15 (15 flashes) Ignition output signal
Code 16 (16 flashes) Fuel injector
Code 17 (17flashes) Vehicle speed sensor
Code 19 (19 flashes) No code 18 for some reason Lock up control solenoid valve
Code 20 (20 flashes) Electric Load
