Old 05-13-2004, 04:39 PM
ashah000's Avatar
ashah000 ashah000 is offline
Send a message via AIM to ashah000
Unhappy Engine Shakes
I just noticed that my engine shakes when I turn off my car. Right after I turn the key you will hear it shake from the driver seat Motor mounts maybe?? I really have no idea!
Thanks guys o and gal
EDIT>>> I just had someone else turn the car off and it it is the engine that is shaking and it looks pretty bad to me
For Sale 98 Eclipse GS, 5 spd
Old 05-13-2004, 08:02 PM
BoostedSpyder's Avatar
BoostedSpyder BoostedSpyder is offline
Send a message via MSN to BoostedSpyder Send a message via Yahoo to BoostedSpyder
Re: Engine Shakes
like a diesel kind of thing? you know like when you turn the key off and it still sputters?
Old 05-13-2004, 08:03 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
Re: Engine Shakes
do eclipse have an engine brake to slow down the engine when you turn it off?
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 05-13-2004, 08:12 PM
ashah000's Avatar
Re: Engine Shakes
Not sure what you mean by the diesel sputtering but it shakes and it is does not sound right. It really sound likes something is wrong.
Old 05-13-2004, 08:16 PM
Nstyle29's Avatar
Nstyle29 Nstyle29 is offline
Send a message via AIM to Nstyle29 Send a message via MSN to Nstyle29
Re: Engine Shakes
Is the RPM high when you turn the car off, cause when i get that damn BS idle surge mine shakes when i turn it off
Check out my 95 GS-T --> http://www.cardomain.com/id/nstyle29
Old 05-13-2004, 08:17 PM
ashah000's Avatar
Re: Engine Shakes
Nope its around 900, 1k max.. but that is my usual idle
Old 05-13-2004, 08:48 PM
Re: Re: Engine Shakes
that seems kinda high for an idle... mine warm is like 300-500 [different gauges and 1/4 inch off will make a 200 rpm diff!] but it is a turbo too and i dunno about the 420a idle speeds...
Old 05-13-2004, 09:06 PM
guitarXgeek's Avatar
guitarXgeek guitarXgeek is offline
Send a message via AIM to guitarXgeek
Re: Engine Shakes
My 2g N/T idles at about 600-800
Old 05-13-2004, 09:48 PM
EclipseRST's Avatar
EclipseRST EclipseRST is offline
Banned
Send a message via AIM to EclipseRST Send a message via MSN to EclipseRST Send a message via Yahoo to EclipseRST
its most likely your gas... you probably go some shitty gas in your car causing it to combust under the heat of the chamber! run some higher octane thru there and it should solve that problem...
as for 1stgenrocks question... no they do not have an engine brake! the only motors that have engine brakes are Semi's and big trucks cause they use them to slow the truck down instead of wearing out the brakes really quick! thats the weird noise you hear when a semi is slowing down, its called a Jake Brake!
Old 05-14-2004, 08:14 AM
ashah000's Avatar
Re: Engine Shakes
Yea I think the idle is high but it has been like that since I bought it so I don't think it is related.
I used 92 octane in my car last time and that is what is in there right now. How could the gas cause the engine to shake.
Also I started to notice that when I take a right turn it makes shaking/rattling noise from the engine. This is scaring me
Old 05-14-2004, 08:46 AM
RiceRocket18's Avatar
RiceRocket18 RiceRocket18 is offline
Send a message via AIM to RiceRocket18
LOL.. you seem to have the worst luck with your eclipse ashah
you're the only one i know so far with an eclipse tha'ts been through hell
i feel your pain
06 Charger SRT-8 black.
Old 05-14-2004, 09:02 AM
ashah000's Avatar
Re: Engine Shakes
lol it's sad but true.
Yea anyone want to come to my house and steal my car and blow it up. Anyone..
Old 05-14-2004, 09:19 AM
Re: Engine Shakes
ya.. anyone?..... it wont' take much
Old 05-14-2004, 09:35 AM
Re: Engine Shakes
just run down there hotwire it and drive it around the block it'll blow up lol jk and whoever replyed about the engine brake that not exactly what i meant but whatever i dont know how to describe what the hell im thinking of
-1stGenRocks-
Old 05-14-2004, 09:59 AM
EclipseRST's Avatar
Banned
Re: Engine Shakes
basically an engine brake is a cover that when you pull a lever or push a button it covers a part of the exhaust slowing the engine down, causeing the tranny to slow the vehicle down! hope that helps!
