Old 05-13-2004, 04:26 PM
KWandKD KWandKD is offline
Arrow BOOST my confidence
OK, The Turbo will be replaced in a few nights and Im ready to do more.
First - I want to get a Manual Boost Controller ( probrably Jope p or apexi') but Im worrying about what has to be done to the ECU to be able to boost higher?
Friends have said something connects to it or that you gotta get a computer chip to change the ECU so it will work right.
WHAT IS THE TRUTH?
I don't wanna F' up anything, so Im asking before I do anything stupid.
Also- Im wondering what mod I should do next - I have the stock turbo replaced, BOV, downpipe w/ exhaust. (105,000 on car)(gsx).
SHould I go with Fuel mods (fuel rail, pump, injectors etc)? Spark plugs? or Should I get a FMIC (If u recommend this, how much more power will it give me[Im still rockin the stock turbo, just newer].?
Thanks - I really need the advice... Add your 2 cents - good or bad...
Old 05-13-2004, 04:58 PM
Also, What is the best/trustworthy company to go with (MBC)? Im only looking to get up to 16 PSI right now. Nothing crazy, but I dont want a cheapy one that'll give me boost creep.
Old 05-13-2004, 05:01 PM
ashah000's Avatar
ashah000 ashah000 is offline
Send a message via AIM to ashah000
Re: BOOST my confidence
What do you plan on raising the boost to?
For Sale 98 Eclipse GS, 5 spd
Old 05-13-2004, 05:08 PM
amdsoldier amdsoldier is offline
Yeah I don't think boosting higher will help you with a stock turbo. So I'd probably upgrade that first with the MBC.
Old 05-13-2004, 05:15 PM
around town probrably just 14, but when I race - 16psi. Its also the stock turbo (off another car w/ low miles, and cleaned).
Old 05-13-2004, 05:51 PM
Nstyle29's Avatar
Nstyle29 Nstyle29 is offline
Send a message via AIM to Nstyle29 Send a message via MSN to Nstyle29
so you still have stock BOV, exhaust, and downpipe? Just a newer turbo?
Check out my 95 GS-T --> http://www.cardomain.com/id/nstyle29
Old 05-13-2004, 05:53 PM
JoeWagon's Avatar
JoeWagon JoeWagon is offline
Banned
Maybe UICP next? Your next upgrade is a real turbo. Fuel pump, injectors, regulator, afc, electronics, plugs, wires or FMIC won't make your turbo any better.
Greddy type S BOV, Upper inter cooler pipe, Apexi' N1 downpipe and exhaust, turbo timer, and I have a fuel managment kit on the way. I need a MBC to get better result from the Turbo. Im not putting a new one in (turbo) becuase within the next year or so I hope to get my friends 6-bolt.
Old 05-13-2004, 05:57 PM
Nstyle29's Avatar
before the mbc you will need an actual boost gauge to tell what the hell ya doin, otherwise could cause some damage
Old 05-13-2004, 08:24 PM
BoostedSpyder's Avatar
BoostedSpyder BoostedSpyder is offline
Send a message via MSN to BoostedSpyder Send a message via Yahoo to BoostedSpyder
Re: Re: BOOST my confidence
this is all so confusing.... compile a complete mod list and put it in 1 place please. i'm too lazy to peice it all together...
and what is the "fuel magmnt" you speak of...
Old 05-13-2004, 08:43 PM
JoeWagon's Avatar
Banned
What fuel are you going to manage? Turbos aren't 7 bolt specific, so you won't be wasting it. There are no mods you can do to be faster on the stock turbo except MBC, intake, and exhaust.
Old 05-14-2004, 08:37 AM
Exclamation
OK, Let me change things around -
HERE is my complete mod list on the 97 gsx.
Apexi' N1 Downpipe
Apexi' N1 exhaust w/ 3" pipe
HKS Turbo Timer Type 1
Air/Fuel gauge
Turbo Boost Gauge
Greddy UICP w/ Type S BOV
full cold air Injen Intake
Newer Garret T25 Turbo (polished)
(not engine) - 18x8 rims.
On The Way (already ordered)
Fuel managment kit (550 Lucas injectors, Walbro (cant remember excact brand) 190 liter/hour Fuel pump, apexi S-AFC II.
The question is - What MBC is the best brand, and what needs to be done to the ECU when I install it.
Also - When Im done with that, what is the next step (besides bigger turbo) should I do to the engine.
sorry 4 the confusion -
Old 05-14-2004, 08:41 AM
RiceRocket18's Avatar
RiceRocket18 RiceRocket18 is offline
Send a message via AIM to RiceRocket18
i believe a bigger turbo with a FMIC after that will give you some significant boost of confidence.
06 Charger SRT-8 black.
Old 05-14-2004, 08:59 AM
LandoAWD LandoAWD is offline
Send a message via AIM to LandoAWD
You are at the limits of the T25.
You don't need to touch the ECU to raise boost, which you shouldn't do on the T25 if you are already running 16lbs.
Almost all MBCs are the same in terms of how they work, so go with a proven one like JoeP, or Hallman.
Kris
2012 Genesis Coupe 2.0t
Old 05-14-2004, 09:04 AM
My fault, I meant that I PLAN to run 16lbs, but now Im still running stock boost. sorry for the confusion -
thanks for the advice lando -
