Go Back   Automotive Forums Car Chat > Dodge > Dakota
Old 05-13-2004, 03:09 PM
nmbr1georgiabitch nmbr1georgiabitch is offline
Send a message via MSN to nmbr1georgiabitch Send a message via Yahoo to nmbr1georgiabitch
98 dakota.....
Hey I need some input...I have a 1998 Dogde Dakota that won't start...I parked it and went to start it and none of the gauges are working and it wont start....it had gas in it when it was parked....and only sat over night.....Anyone who would know what the problem is will be greatly appreciated....
Shauna
Old 05-13-2004, 06:47 PM
BleedDodge's Avatar
BleedDodge BleedDodge is offline
Send a message via MSN to BleedDodge
Re: 98 dakota.....
Maybe someone played an evil trick on you and disconnected your battery...
So what else happened? You say it won't start? Does it do nothing, click, or crank but not fire up when you turn the key? What's going on with it?
Old 05-13-2004, 06:53 PM
Re: Re: 98 dakota.....
LMAO......nah i checked those first:P ......
Well what happened was I went out Saturday morning about to leave to go shopping and it showed I was out of gas.....but it had 1/8 of a tank when I parked it Friday night....so I went and got gas put it in.....and it still wont start.....it will turn over but thats about all it does.....now none of my gauges are working.....someone said it was my fuel pump but will that make all of my gauges quit working????
Old 05-13-2004, 07:01 PM
BleedDodge's Avatar
Re: 98 dakota.....
Sounds like major electrical trouble. I don't know what to tell you. I don't think you can fix it yourself though, you should get someone you know who is good with cars to look at it, and if they can't solve it, have it towed to a shop and get it fixed I guess.
Maybe someone else will know something here...
Old 05-13-2004, 07:03 PM
Unhappy Re: Re: 98 dakota.....
Thanxs....my dad is out there working on it he got the gauges working...but no luck in it starting....
Old 05-13-2004, 07:06 PM
BleedDodge's Avatar
Re: 98 dakota.....
The first time the catalytic converter clogged up on my truck, I parked it, and went to try start it about 2 and a half hours later and it wouldn't fire up. Took me forever to figure out what it was. What I did was remove the pre-cat oxygen sensor, and stuck a metal bar and then a cordless drill inside to chew up the catalyst, or brick, that's inside, to make the truck run again. This is one possibility. I don't understand why your guages would give up on you though...
Keep us posted.
Old 05-13-2004, 07:09 PM
Keep us posted.
Yeah me either.....But you know I am a woman ...lol and know nothing about cars. But I appreciate your help.
Shauna
Old 05-13-2004, 07:13 PM
BleedDodge's Avatar
Re: 98 dakota.....
Tell your dad to try taking an oxygen sensor out and then crank it over, it just might work. I bet your exhaust is plugged.
I ended up having to rip my exhaust apart to fix all of this. Is your check engine light on, when you have the key on?
Old 05-13-2004, 07:18 PM
My check engine light isnt on...but I will definitly tell him to check it...thanxs
Old 05-13-2004, 07:25 PM
BleedDodge's Avatar
Re: 98 dakota.....
It must be something simple.
Old 05-13-2004, 07:27 PM
I hope so because Ilove my truck
Old 05-19-2004, 06:24 PM
dralin dralin is offline
Re: 98 dakota.....
Might want to try taking the battery in to get tested, I know DC put in a 7 year battery in the dakotas, at least in mine, so it could be about time to replace that...
May want to check the insides of the battery connectors (the part that goes around the post). I had some corrosion building up between my connector and the terminal, so my truck wouldn't start.
Old 05-19-2004, 07:19 PM
BleedDodge's Avatar
Re: 98 dakota.....
She says it turns over though.
