Blown head gasket fix
Anyone use or hear of RXAuto.com? I have a 93 Camaro 6 cylinder
with a blown head gasket. This place advertises a liquid fix for about a 100 bucks! Advertisement shown below... ThermaGasket Will Repair The Following Problems: Failing Head Gaskets Warped Heads Cracked Heads and Engine Blocks Coolant Leaks Between The Head and Block To The Exterior Of The Engine Coolant Seeping Up Through The Headbolts Intake Manifold Coolant Leaks Over Heating Problems Due To A Cracked Head or Block Sounds to good to be true. Usually means it is. Thanks in advance. |
Re: Blown head gasket fix
i wouldnt trust it
1968 Camaro 327 1999 Silverado 1500 Z71 LT {o,o} |)__) -"-"- O RLY? http://www.cardomain.com/id/korndogg002
stuff like that can clog up your water jackets, among other things, i would just replace it
the best replacement is the stock part
i always use fel pro gaskets
Thanks for the quick responses.
