Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 05-13-2004, 01:43 PM
LordJezo LordJezo is offline
Where is the fuel filter on the '03 Impala LS?
Has anyone changed their own fuel filter on a newer Impala? Where do I find it?
Old 05-14-2004, 12:39 AM
bermis519 bermis519 is offline
Send a message via AIM to bermis519 Send a message via MSN to bermis519 Send a message via Yahoo to bermis519
Re: Where is the fuel filter on the '03 Impala LS?
I have a 2000 impala and i was told that it's by the rear passenger wheel. I bought a filter to put in mine and I looked briefly for it, but I couldn't find it, doesn't mean it's not there. I'm going to change mine soon and i will let you know...
mike
Old 05-14-2004, 06:20 AM
Thanks!
I have 33k miles on the car and want to change it myself if possible.. don't want to pay!
Old 05-16-2004, 12:49 PM
victimizati0n victimizati0n is offline
Send a message via AIM to victimizati0n
Fuel filters last alot longer than 33k miles.
But anyway, look by the passenger rear wheel, you will see the gas tank... look in front of it, and you will see it.
Old 05-16-2004, 04:04 PM
How many miles should I wait before worrying about it then?
Old 05-30-2004, 01:35 AM
rob USN rob USN is offline
Fuel filter location
Hello,
I have a 2000, but the 2003 should be the same. The fuel filter is right in front of the gas tank on the driver's side. You need a pair of needle nose pliers, a 5/8 and a 13/16 wrench to remove it. My car has 56000 miles on it and I should have replaced it sooner. The car fires up much more quickly and has much better throttle response with the new filter.
Old 06-16-2004, 12:18 AM
[ZNP]maccypoo [ZNP]maccypoo is offline
the fuel filters in the newest impalas are right at the front of the engine behind the front bumper. theres a little plastic door that says fuel filter on it
Old 06-16-2004, 09:27 AM
WGP WGP is offline
Thanks for the info! I'll check my 04 when I get home...
Bill
2003 2500HD LT Duramax CC SB 4WD,OilGuard BypassFilter, JK MegaFilter, LiftPump/PreFilter, Bilsteins, Retrax RollTop, J&J Millenuim Boards, Coolant Filter, Alli-deep-pan, High Idle, Mods UOA History
04 Impala, 99 Saturn SL1
Old 06-19-2004, 03:16 PM
Master Tech Dude Master Tech Dude is offline
All the front wheel drive GM cars I've ever seen had the filter mounted inline near the fuel tank as was stated earlier...I am also fairly sure that filter referred to in the front of the car could only be the oil filter. Someone correct me if I'm wrong.
