Old 05-13-2004, 01:11 PM
lukedwag lukedwag is offline
95 rear brakes are hanging up when warm
changed the rear brakes 2 weeks ago now its hanging up as soon as they warm up. they bind and I can barely turn the wheels when I jack it up. the calipers seem ok since I can turn them in and out except for the last .25 inches of so when I compres them all the way. I loosened the bleed screw to seee if there was air in the lines but I can get the mighty vac to take fluid out it builds vacum but wont take fluid out.
rear rubber lines colapsed ?
rear calipers ?
ABS problem ?
Old 05-13-2004, 10:21 PM
irish30's Avatar
irish30 irish30 is offline
Re: 95 rear brakes are hanging up when warm
Try to push the caliper piston back to see if it seized. If it won't go then open the bleeder screw and try to push them back. If they go back and and fluid pisses out then it's the rear flex hoses. I replaced both of mine two years ago. My car is a 98 Taurus SE. They collapse inside restricking the fluid flow.
