Old 05-13-2004, 12:26 PM
Racincc85's Avatar
Racincc85 Racincc85 is offline
Send a message via AIM to Racincc85
Question about diesel engines
Why is it that diesel engines have so much torque and so little horsepower, and why are their operating speeds so slow compared to gasoline engines?
Old 05-13-2004, 12:51 PM
SaabJohan SaabJohan is offline
Re: Question about diesel engines
Diesel engines can't work at high speeds due to their slow combustion. They are therefore designed for low speeds and their higher efficiency make it possible for them to make more power at low engine speeds and since power = torque*angular velocity their torque will be higher.
Old 05-13-2004, 02:16 PM
59elcooldsuv's Avatar
59elcooldsuv 59elcooldsuv is offline
Another factor is that they usually have a very high compression ratio, at least compared to what we are used to in gasoline engines. Diesel fuel requires this high compression and it does result in a great dal of combustion force on the piston.
For reasons stated by Johan the also are designed with a long stroke which means better "leverage" on the crank.
Randy Scott - Houston Tx - 59 El Camino (Old SUV) - 348W in shop for future street rod project to be announced
Old 05-14-2004, 02:13 PM
Re: Re: Question about diesel engines
The high compression ratio is one of the reasons for its high efficiency.
The leverage on the crank doesn't affect the torque, a long stroke must however be used to make it possible to use high compression ratios and high piston speeds for better cylinder filling at low speed. The large stroke to bore does also decrease heat losses in the cylinder.
Old 05-14-2004, 02:57 PM
The leverage on the crank DOES affect torque - that's why torque is measured in pound/feet (or Newton/meter) - it's a function of a certain amount of force (pound) applied at a certain distance (feet) from the rotational centerline. If this isn't clear try loosening a bolt with a short wrench, then try it with a longer wrench. That's torque; and it's a function of leverage - by definition.
There are other ways to increase compression without increasing the stroke, such as a smaller combustion chamber.
There are other ways to increase cylinder filling, such as larger valve area.
Old 05-18-2004, 11:13 PM
Doug Rodrigues Doug Rodrigues is offline
Send a message via MSN to Doug Rodrigues
One of the best engines made for torque was the old WW-II Jeep 4-banger engines. They had the longest engine cylinders for their size to allow for a very long stroke. Very long stroke means a very long "arm" on the rod journals. Very long "arm" means more leverage on the crankshaft turning, equals more torque. That thing at idle could still drive over humps that more modern 4-wheelers had to throttle-up or stomp the gas pedal hard. However, unlike the more modern engines, the RPM range was restricted.
Old 05-19-2004, 12:56 AM
Evil Result Evil Result is offline
Send a message via AIM to Evil Result
i'v been wonderning, because of diesels slower combustion rate. What would be the effects of a diesel operating at 9500 RPM. would the torque output fall off quicker at Higher RPMs than compaired to a gasoline engine? Or can't the injectors keep up to a pace that fast?
I know that to rev at 9500 rpm you will need a short stroke, which will reduce torque output and lower the compression ratio but compression can be corrected with a smaller bore.
I disregard my perceived image in the persuit of knowledge.
Old 05-19-2004, 01:37 AM
To my knowledge, diesel engines are low RPM engines and have a narrow RPM range for maximum power. For example, today I drove a diesel engined truck crane that has a 15 speed transmission. For normal driving, I use the top 9 speeds. Maximum power was between 1900 to 2300 RPM. 2300 was maximum governed engine speed. That 400 RPM range is so narrow that "splitting" the gears is a necessity, otherwise the engine would lug-down. A gasoline engine has a much wider RPM range of smooth continuous power output. Listening to the diesel engines in automobiles and pickup trucks, they also sound to be low RPM engines. The main advantage of diesel engines is that one gallon of diesel fuel puts out more BTU's than one gallon of gasoline. That translates into better mileage.
Old 05-19-2004, 08:54 AM
Originally Posted by Doug Rodrigues
One of the best engines made for torque was the old WW-II Jeep 4-banger engines. They had the longest engine cylinders for their size to allow for a very long stroke. .
Wasn't that the "Go-Devil" engine?
Old 05-19-2004, 08:57 AM
Originally Posted by Evil Result
i'v been wonderning, because of diesels slower combustion rate. What would be the effects of a diesel operating at 9500 RPM. .
In all probability the intake & exhaust passages would restrict breathing enough to prevent that from ever happening.
A high RPM engine will have a larger cross-section to the ports for easier breathing at high rpm. Resticting the size of the port restricts the rpm. That's how a throttle works - by restricting the intake passage.
Old 05-19-2004, 08:37 PM
I don't know what they called the WW-II Jeep engine. The only thing I thought when preparing to sleeve one of the cylinders was, "Holy smokes...where am I going to get a sleeve that long!"
Old 05-20-2004, 03:40 PM
A longer crank leverage DOES NOT affect the torque from an engine, this seems to be a common missunderstanding. With a given cylinder pressure and cylindervolume you won't get any extra torque by increasing the stroke, only if it increases the volume. This since, for a given volume, if you increase the bore you will get a larger area and therefore a higher force but the radius the force act on is smaller so the torque will be constant. This will also be the situation if the stroke is increased and the bore reduced but then the force will be smaller instead and the radius larger.
Do design small combustion chambers on an large bore, small stroke engine for a high compression ratio is a diffucult task if the flow should be high. However you design it, it will have some downside. Therefore a large stroke will be needed to reach higher compression ratios.
Diesels can't work at high engine speeds, they won't have the time needed for the combustions. Like all engines they have a torque curve that at higher engine speeds will be negative, that is, it will need power from another source to run at those speeds.
Old 05-20-2004, 04:41 PM
As far as I know, that WW-II Jeep engine wasn't a high compression engine and was designed to run on very poor quality gasoline. Okay, I'm not an engine design engineer, but I do have a question. Lets say that we have two 4 cylinder engines. One engine had a small bore and long stoke. The other engine has a large bore and short stroke. Both engines are designed to produce exactly the same horsepower. Which one has the greater torque and why?
Old 05-21-2004, 07:29 PM
If you make two engines like this, the one with the shorter stroke will need to work at higher engine speeds, it will therefore produce a higher power. The torque will be pretty much the same for both engines, however, since the large bore engine run at a higher speed that engine will likely have a slightly lower efficiency and therefore produce a little less torque. However, that difference will be very small.
Old 05-21-2004, 08:19 PM
beef_bourito's Avatar
beef_bourito beef_bourito is offline
my understanding of stroke is that higher stroke engines with smaller bore will produce more torque at lower rpms than small stroke, big bore engines with the same displacement but they will produce around the same peak power also at lower rpm. is this correct (I'm asking you johan because i know you always provide good insight)
Mr. T doesn't pity anyone who likes the Black Eyed Peas. He just kills them.
Mr. T speaks only when necessary. His main form of communication is folding his arms and slowly shaking his head. And regardless of the situation, he is always understood.
On the A-team, Face , Haniabal, and Murdoch were all masters of disguise. Mr T didn't have to wear a disguise. The bad guys didn't recognize him out of fear.
