GC don't start
Hi. I have a GC 1993. It works very well until this morning that doesn't want to start. All ligths turn on (Check engine included) as normally, the sparks,fuel pump, battery & alternator are working, self check send only the code 55 that I suposse its ok. Actually I go to work yesterday and it works good. Can some body help me? It could be the computer? How can i get a fuse diagram?
Re: GC don't start
Re: GC don't start
Go back and check your battery again..GC puters are very sensitive to low volt readings and is typical of no start condition.
I check it
I check both plug and coil wire, Everythings looks normal, actually i clean it. The baterry has 13v but when I try to start it it downs to 9 volts in the voltimeter. So i put another battery that i have but doesn't work. It could be the problem? How to know if is not the computer with out a scanner? (I try the self check as a mentioned before, but only send the code 55 and a week ago It sends the code 17 "Engine stays cool too long" but I change the thermostat so that problem it's fixed ). And a last question, In normal conditions what must to send the self check?
Thank you so much to everybody |
Re: GC don't start
EMAIL [email protected]--i send info, dale |
I got the code but thanks any way. Now im trying to find the Fuse's diagram and the Owner's manual on the web (I lost it 3 months ago 1 week after I buy the Jeep
Re: GC don't start
I don't know how to check computer without equiptment. Try switching the fuel pump delay fuse with the ASD relay fuse(Black fuse box on fenderwell)....just brainstorming for now.
Re: Thank you Dale
