Old 01-16-2002, 06:07 PM
Drocca91's Avatar
Drocca91 Drocca91 is offline
Send a message via AIM to Drocca91
EGR on my 4th gen accord?
the ecu detected it there was something wrong with it. what is it and how can i check it? thanx
91' CB7
Old 01-16-2002, 06:36 PM
fritz_269's Avatar
fritz_269 fritz_269 is offline
http://autorepair.about.com/library/...erms=EGR+valve
It's a common problem for EGR valves to stick. Fortunately they're easy to replace, but not necessarily cheap. It's also conceiveable (but less likely) that the EGR solenoid is sticking, busted, or disconnected. The EGR solenoid is what the ECU uses to control the vacuum signal to the EGR valve.
Old 01-16-2002, 08:33 PM
Drocca91's Avatar
thanx for the really help full hint fritz!
91' CB7
h23 swap 4th gen civic? 92lude91dx '88 - '91 Civic | CRX | Wagon | Shuttlee 4 03-16-2009 11:43 AM
4th Gen Accords Defender Accord/TSX/Accord Hybrid 32 03-02-2002 11:50 PM
tail lights for a 4th gen accord iT90accord Accord/TSX/Accord Hybrid 1 02-27-2002 09:43 PM
starting valve and hose #8 from pgm-fi on a 4th gen accord? Drocca91 Engineering/ Technical 0 01-16-2002 08:57 PM
