Old 05-13-2004, 07:43 AM
aznnutty aznnutty is offline
Question programming car alarm remote
alrite, my alarm remote is betting bad, ether it's running out of batteries or the remote is bad itself, but i'm going to change the batteries. is there some kind of programing for the remote or do you just switch the batteries with out a problem? this is to a first gen sl 93. if you do have to program it, how?
Old 05-13-2004, 11:40 AM
Igovert500's Avatar
blue + red light magnet
Re: programming car alarm remote
I have to do the same thing, and I was told that you can buy hte batteries at walmart really cheap and you just need to replace them. You don't need to reprogram it. However, someone did mention that some of the remotes have short term memory, in other words, you may only have 30 seconds or so to change the batteries.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 05-13-2004, 01:21 PM
azn3000GTRacer azn3000GTRacer is offline
I was wondering when i lock my car i dont get the "cool" beep beep, well i think it's cool. Can you reprogram your alarm to do that?
Old 05-14-2004, 07:21 AM
the beep beep means the alarm is on, if you don't get the beep, then you have a problem with the alarm. try pressing it twice, maybe you have a different alarm system. alot of cars have two stage alarms.
Old 05-14-2004, 08:50 AM
ok, so what's the size and type of battery is it? and this is for the 1st gen, 93
Old 05-14-2004, 02:47 PM
No my car alarm locks when i press the button i just dont get the "beep beep"
Old 05-14-2004, 11:23 PM
youngmanvr4 youngmanvr4 is offline
I have a Viper alarm system on my 95 Base put it came with it...and it makes like a "beep beep" sound then if you press it again it makes a "beep beep" then a wisle sound. Do you know what the wisle sound is?
Old 05-15-2004, 09:41 AM
ponchonutty's Avatar
ponchonutty ponchonutty is offline
Re: Re: programming car alarm remote
You mean when you go to unlock/disarm you get 2 beeps. Well, unless the alarm had gone off then you will get 4 beeps. If you press to lock/arm you should get one beep. If you press the lock button again, you'll get the double beep plus a whoop. That's telling you that you have turned off part of your alarm. There are different parts of your alarm that you can have armed and disarmed at the same time. So, say that you have bad door triggers or know that you'll be in a very noisy area that could set off the impact sensor, well you can turn those parts off but still have the rest of the system on. Read your manual.
Old 05-15-2004, 10:22 AM
Yea..i got ya now...if i press the lock botton one time it makes a beep then if i press it again it makes a beep beep whoop sound.
When i got my car it didn't come with the manual.
Old 05-15-2004, 07:29 PM
GOTO www.directed.com and you can download a PDF file of your alarm. Look under guides.
Old 05-16-2004, 01:02 AM
How do u get the stock alram to go "beep beep"??? i want that sound but dont want to buy a new alarm system iam happy with the one i got now except that it dosent go "beep beep"
Old 05-16-2004, 10:19 AM
3kgt95 3kgt95 is offline
Send a message via AIM to 3kgt95
mine goes beep beep but i don't know how and why does the alarm go off when i unlock the door with the key
Old 05-17-2004, 06:59 AM
If it is aftermarket, all alarms will go off when you open the doors without using the keyfob. If it is OEM, my guess is either the switch in the door is bad or the disarm wire is faulty. They are very simple alarms to work on.
Old 05-20-2004, 04:11 PM
Re: Re: Re: programming car alarm remote
I like the alarm on the car and everything but do you know how to stop the alarm from going off when i unlock the door with the key?
