Old 05-13-2004, 12:17 AM
korndogg's Avatar
korndogg korndogg is offline
Send a message via AIM to korndogg Send a message via MSN to korndogg Send a message via Yahoo to korndogg
Powerglide to 700R4
Ok so do you guys think its a good idea that im replacing the powerglide with the 700r4?
Old 05-13-2004, 12:20 AM
96CamaroSS's Avatar
96CamaroSS 96CamaroSS is offline
Re: Powerglide to 700R4
In my opinion the powerglide is a better trans, but the 700r can give you some better fuel economy and you can use any gear ratio with it.
Old 05-13-2004, 12:25 AM
korndogg's Avatar
well see. isnt a powerglide basically better for more HP? cause all i got is a 327 and its just so slow accelerating.
Old 05-13-2004, 12:29 AM
96CamaroSS's Avatar
Re: Re: Powerglide to 700R4
Wel the powerglide is good for race applications but it can be good for the street... What gear ratio do you have?
Old 05-13-2004, 12:31 AM
korndogg's Avatar
i actually have no idea. havent gotten around to looking. i just bought the car in fall and it was in storage most of the winter. is there any easy way of finding out without taking the pumpkin apart?
Old 05-13-2004, 12:32 AM
68chevelle 68chevelle is offline
Send a message via AIM to 68chevelle
go with the 700. i dont think in any way the powerglide is better. the only way it posibly is, and the only way my dads 67 chevelle can keep up with a car is because you only shift once. thats the oly benifit to it, but then that brings alog with it many other problems. you will accelorate faster with the 700, you will be able to run different gears in your rearend to accelorate even fast yet still be able to cruse on the highways at a very comfortable RPM and you will get good gas milage. i see no reason to keep the powerglide over a 700. unless you dont have to money for the swap. i am in the process of swaping over to a 2004R from my 350, my car originaly came with a powerglide that i swaped out the the 350. if i had the money ever old car i ever own/will own will get a overdrive swaped into it. i would say go with tht 700.
Old 05-13-2004, 12:34 AM
the powerglide is good for raceing obnly if it is built for it. not stock, they must be built extesivly.
Old 05-13-2004, 12:36 AM
korndogg's Avatar
well i bought the tranny for which i thought was a hellova deal. i got it for 350 bucks. now all i need to do is adjust the crossmember, get the driveshaft shortened, and im puting in a floor shifter so i need to get that. oh and the torque converter which im not getting a lock up cause theyre so damn expensive.
Old 05-13-2004, 12:42 AM
well umm 350 is a hella good deal. even with what you have to do still. adjusting the crossmember is no big deal, like i was talking about before i think you should just slide it back instead of cutting and welding, its alot easier. all you would have to do is maybe drill a couple new holes and your good to go. the driveshaft, i dont know how much that is going to cost you but its gotta be done. and yeah just you might want to concider putting on a aftermarket trans cool aslo cuz the non-lockup converter will create more heat. oh you do know about setting up the TV cable right. that must be done corectly or it will screw up the trans, and the overdrives are way different that a powerglide 350 or 400. totaly different setup. if you want let me know and i will give you a link to a place that will have everything you want to get it set up correctly. they make the best setup i have ever seen.
Old 05-13-2004, 12:44 AM
ridge_runner ridge_runner is offline
Send a message via AIM to ridge_runner Send a message via MSN to ridge_runner
yea go ahead and post that link if you dont mind.. id like to take a look at it...
Old 05-13-2004, 12:45 AM
korndogg's Avatar
yeah sure ill take the link cause i dont know how to set up the TV but i kno its gotta b done and with the crossmember, im not the one thats gonna b cuttin and welding. the guy i bought it from is gonna do it for me for free . and yeah im gonna get a cooler i forgot to put that in the post lol.
Old 05-13-2004, 12:47 AM
korndogg's Avatar
oh and um. when i start my car sometimes it takes a while and when its running and getting up to running temp i have to let it run for like 5-10 minutes cause if i put it in reverse or drive it will stall. you think thats the timing?
Old 05-13-2004, 12:50 AM
here this is a link straight to the page for the TV ststems. its comes with everything and good instructions. just pick what carb you have, and i think they also have them for TPI and stuff like that.
http://www.bowtieoverdrives.com/cata...BCAT&CATID=WA3
if you go the there home page they have all kinda of stuff and info on all sorts of stuff. but that TV cable and brackets and everything sets it up perfectly and is the best i have ever seen.
Old 05-13-2004, 12:51 AM
sweet.... thanks
it could be the timing, carb, no choke, something isnt adjusted right. it could be alot of things
