Old 05-12-2004, 08:22 PM
weirdALJR weirdALJR is offline
Electrical Problem? Cutting Out.. HELP!
OK new problem I need some help with, on a 90 gt. All the sudden yesterday my car started cutting out, while acceleraqting in every gear it cuts out for a split second, looses all power but dosen't stall most of the time, its so quick the car jerks (rpms drop to 0) but it get power back so fast it keeps going... sometimes it stalls. Now heres the next twist, i drive it about 5 times yesterday it did exactly what I said 3 of the drives many times for the whole drive, the other 2 times in the middle it has no problems at all, I reved it up and raced it a bit to test it and no problems, but later that night it was back. Last full tuneup was about 1 month ago.
Old 05-12-2004, 08:26 PM
stang_racer20's Avatar
stang_racer20 stang_racer20 is offline
Send a message via Yahoo to stang_racer20
It's possible that its an electrical problem, but I'm thinking its possibly fuel related. Do you have any mods? Sometimes when engines do that, not always, its cause of a lack of constant fuel pressure. Otherwise how old are the plugs, wires, cap/rotor, etc?
92 Mustang GT, 347 Stroker(Forged Steel Crank/Rods-Balanced, Forged Alum Dished Pistons), B50 Block, Track Heat Intake, Twisted Wedge Heads w/ Stage 3 port/polish, 80mm C&L MAF, FMS 30# Inj., BBK AFPR, Trick Flow Stage 2 Cam, Trick Flow 1.6R Rockers, BBK EL-CC Headers, MAC O.R. H-Pipe, Flowmaster Cat-Back, Accufab 75mm TB, MAC CAI, BBK Pulleys, Griffin Alum Radiator, Mark 8 Fan, MSD Pro-Billet Distributor; AOD, Dynamic 3300 L-U Converter, B&M Trans Cooler; 3:73 gears.
Old 05-12-2004, 08:32 PM
Re: Electrical Problem? Cutting Out.. HELP!
Lugs, Wires, Cap, & Rotor are all less then 1 month old. Only mods where Cold Air Intake, preformance pulleys and new alternator.
Old 05-12-2004, 08:33 PM
Sorry Plugs - I doubt the Lugs are related to this issue -
