Old 05-12-2004, 04:20 PM
Dr Juice Dr Juice is offline
Send a message via AIM to Dr Juice Send a message via MSN to Dr Juice
Engine additives
I see alot of this stop smoke, and oil treatment stuff. Is there any additive to put in your motor that will help. I know there is a wide range of options, but are there any that work
Old 05-12-2004, 08:36 PM
SenseiAccord SenseiAccord is offline
Re: Engine additives
to me i dont think any additive will stop a smoking car. For example if u have white smoke shooting out of the exhaust.. then the headgasket is blown and nothing will stop that other than replacing the gasket. Same thing with other stuff... oil burning... running rich... etc etc. Nothing fixes that better than replacing the problem or fixing it from a mechanic. Additives will probably stop something for temporary.. but not for long. Injector cleaner and sh*t like that works good. Its good keeping those things clean. Off topic... fix-a-flat never works. Dont buy that sh*t! just get it fixed at a gas station or shop and fix it for good... or just buy a new set of tires u can afford it like nothing.
Old 05-13-2004, 10:50 AM
Tranzlogic Tranzlogic is offline
Send a message via AIM to Tranzlogic
well just because its white smoke doesnt mean its a headgasket problom..and most injector cleaner is just kerosene which is worthless and not good for injector o-rings ...you need to use something like a BG 44k or injector cleaner..basically something that isnt kerosene, just read what the product contains before you buy it !
as far as stop smoke and things of that nature...its worthless, all it does is dense your oil and attempt to form a " clog " around the leaking part(s)..this in return is not good for the rest of the engine as a whole.....so in that aspect sensei is correct..the problom needs to be addressed and fixed
Old 05-14-2004, 02:21 AM
Re: Re: Engine additives
ok yea white smoke doesnt neccessarily mean its the headgasket but it is the most common problem. Could be the cylinder has a leak and blah blah... just an example. anyway i forgot about BG44k... that sh*t is really good. I also hear those chevron techron bottles are real good.
Old 05-14-2004, 08:21 AM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
yea all these additives are just temporary fixes and dont really do anything to solve the problem, but the best additive ive seen that lasts for years, is a product called Marvel Mystery Oil, people in the auto store i worked at, swear by that stuff.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 05-14-2004, 11:20 AM
i stand behind BG products all the way , but they are additives, not temp problom fixers..you still need to address the problom
Old 05-14-2004, 07:09 PM
crash&burn crash&burn is offline
Send a message via AIM to crash&burn
i was watching this car show on tv and there is an additive that adds 5% more hp. They ran the car on the dyno to prove it and the car gained something like 7 extra hp or something. i thought that was pretty interesting.
Old 05-14-2004, 07:31 PM
sofast's Avatar
sofast sofast is offline
Send a message via AIM to sofast Send a message via MSN to sofast Send a message via Yahoo to sofast
I was an oil/additive tech for years. Any additive that claims to boost or fix your vehicle is junk. There are some that help with engine wear. I swear by Lucas. It helps with friction. It can be used with conventional or synthetic oil. It is used by Semi drivers who but millions of miles on. Slick 50 is junk. Claims to have teflon that bonds to your engine components. Your motor doesnt run hot enough to bond teflon. As for head gasket problems the easy way to tell is if there is fluid leaking from the exhaust or taste the oil off of the dip stick. If it is sweet you have antifreeze in it.
Old 05-15-2004, 01:41 PM
udelblue udelblue is offline
also if your oil has a white look to it there is antifreeze in it. i had the same problem years back it sux! btw lucas is the bomb: i highly recommend sea foam that stuff is wonderful especially on older engines. I heard octane boost works great if you want to add a couple ponies but i never tried the stuff myself.
Old 05-17-2004, 02:39 AM
Prelewd's Avatar
Prelewd Prelewd is offline
Send a message via AIM to Prelewd
I've used Rislone Engine Treatment a couple times, and it seemed to smooth out and quite down the engine a bit..
Soon..
Cars:
1990 Nissan 300zx Twin Turbo
1992 Honda Prelude Si 4WS H22a Swap - For Sale
1965 Chevrolet 1/2 Ton - 500ci Cadillac Cometh
1970 Datsun 240z - For Sale
1972 Datsun 240z - For Sale
1977 Datsun 280z - For Sale
1991 Infiniti Q45 - Engine Donor to 240z - Parting out the Rest
Sold Cars:
1976 Jaguar XJ-S - Rear end Donor to Chev Pickup
1971 Datsun 240z
1984 Civic 1500 Hatch
Old 05-17-2004, 10:28 AM
rislone is junk and terrible for your engine..i mean did you see how thick it was while you were pouring it in..thats just goo that blocks around seals and so forth...not reccomended
Old 05-17-2004, 05:51 PM
tranzlogic do you suggest anything beside lucas products. i have used lucus and they are excellent i dont doubt that. but have you tried anything else that is any good? btw i highly recommend sea foam (can get at napa and bmw dealerships)
Old 05-17-2004, 07:03 PM
Prelewd's Avatar
It was just recommended by a couple people I know because they liked the effects on their cars. Personally, I didn't see enough good coming from it to keep using it.
Soon..
Cars:
Sold Cars:
1971 Datsun 240z
Old 06-30-2004, 02:25 AM
RPMtuner RPMtuner is offline
red line, Motule and only 20/50
Old 06-30-2004, 11:36 AM
redline you have to use with water and its not an additive to the coolent. i dont recommend it from personal experience
