Old 05-12-2004, 02:32 PM
Jimgam Jimgam is offline
In dash Video display while driving
I just bought and had installed a new Kenwood DVD player. Does anyone know how I need to go about disconnecting the device that does not allow for videos to be played while driving? I know that it is somehow engaged by the parking brake...
Old 05-12-2004, 11:11 PM
SickVette SickVette is offline
Send a message via AIM to SickVette Send a message via MSN to SickVette Send a message via Yahoo to SickVette
Re: In dash Video display while driving
If you have the installation manual it will tell you the wire that is intended to go to the ebrake. I have not installed a Kenwood in a while but it is most likely a negative trigger. If that is the case you just need to disconnect that wire from the ebrake and ground. If it is positive trigger then it will need to go to a switched 12v source. But verify with your install manual.
1999 Corvette coupe 600rwhp and way too much stuff to list everything here.
Audio Pioneer AVH P7500 DVD w/xm
2 PG Ti 600.2
1 PG TiDEQ
Stinger battery,alternator,wire,cap,fuse blocks
1 JL 12w6v2
1 7" monitor in rear
MB Quart 8" 4" and tweet in each door
Custom fiberglass,plexiglas, and aluminum amp rack
carbon fiber sub enclosure
Old 12-04-2008, 06:19 PM
ryager ryager is offline
if you have an older one, take the wire that is suppose to connect to the e-brake and ground it elsewhere. All the e-break is doing is completing the circuit when pushed down so the video feed comes in, but grounding it elsewhere will also keep the video feed. Remember though it is pretty stupid and also very illegal in most of the US to watch videos while driving, so if it is in dash, then you are allegedly watching movies or videos. I also have an indash monitor i never once watched a movie while driving down the road, i will keep the monitor shut and listen to the movie (i know the ones i watch pretty well) until i pull over for some rest when driving long distances. But also if you get some illegal tint the fine is much cheaper than the fine for watching a video while driving. GPS navigation systems do not apply to this field, they are perfectly legal to use while opreating the vehicle.
Old 12-05-2008, 05:31 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
Even thought they are ten times more demanding of your attention while being used
