Old 05-12-2004, 01:13 PM
equalizir equalizir is offline
Offset balljoint?
hey guys I was just at my local tire place getting my "89 crx si aligned cause im putting on new tires and wanna make sure everything is cool.This guy tells me i need a offset balljoint for each side of the front.Ofcourse the parts are 300 and labor is $150.The thing is ive never heard of an offset balljoint.I asked the guy if they aligned my car and they said everything is at centered o.but he said the tires will wear uneven without the offset balljoint cause the tires wont stand up like they should.but im confused,if the alignment is done and its centered it would seem to be a waste to add these balljoints?Do i really need these or are they just trying to get more money outta me?any advice would be much appreciated.thanks in advance
I forgot to mention that i have ground control coilovers and agx shocks.its lowered about three inches if that makes a difference.
Old 05-12-2004, 05:58 PM
dfarres's Avatar
dfarres dfarres is offline
Send a message via Yahoo to dfarres
Re: Offset balljoint?
even if your alignment is set your camber is still gonna be way off if you're dropped that low. which will make you ride on the inside of your tires. unless you wanna fork out the big money for ball joints you should just buy a camber kit for around $100 and install it yourself and then take it back in to get it realigned.
1993 Civic Coupe EX
1997 Chevy Suburban LT
“It's all fun and games - Until someone loses an eye"
Old 05-12-2004, 06:01 PM
oh i have camber kits on the front and back.the guy was trying to say that those dont help a hundred percent.but ive had my car aligned at some other reputable places and they've never said anything about a offset balljoint.
