Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 05-12-2004, 01:01 PM
mkamdar mkamdar is offline
Unhappy 96 Camry - Power Antenna Problem
The antenna keeps getting stuck when I turn the radio on. If I pull it out manually it comes out. Also, when the antenna is stuck, it makes this loud whirry noise. Once I manually pull it up, it is ok. It goes down ok. I was told that may be the mast broke. I ordered a new antenna and put it in. I noticed that the old mast was not broken. Also, even with the antenna and mast - still have the exact same problem. Please help.
Old 05-12-2004, 04:14 PM
calvic calvic is offline
Are you sure you got out all of the mast leader out with the old mast. Sometimes it breaks off and stay in the motor section. If the motor sections screwed up, you can get a replacement antenna off of e-bay pretty cheap.
JJ
1988 Camry LE
4 cyl Auto
335,731
1994 Volvo 940 Turbo
1992 Dodge Cummins Turbo Diesel
2006 Mustang GT
Old 05-13-2004, 08:43 AM
Hello Calvic:
I did get all of the old mast out - the length of the old mast and new mast were the same. I am hoping you have some more insight for me. Thanks.
