Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 05-12-2004, 09:27 AM
camry_owner camry_owner is offline
'92 Camry Rear Door Panel Removal...please help!
I need to get the driver's-side rear door panel off of my '92 camry. I've taken out every screw I can find, but I can't get the door to come off. The back window won't roll up and I need to check it out ASAP! Can anyone tell me how to remove the door? Thanks for the help!
Old 05-12-2004, 11:39 AM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: Inside Rear Door Removal...please help!
There are alot of clips around the bottom of the door. Are these your only problem?
Old 05-13-2004, 10:24 AM
swaghole swaghole is offline
Re: '92 Camry Rear Door Panel Removal...please help!
You need to remove the arm rest - it has 2 screws hidden behind plastic cover. They are easy to remove. Once you get these off, you need to pull on the bottom of the door panel to unclip it - there are about 10 clips holding the panel in place. Pretty easy till now. THe last part you need to remove is the plastic door handle cover on the inside panel. This part is hard to remove. It is held in place by 2 clips - one located at the top in the middle and one located at the bottom also in the middle of the cover. You might break it - no big deal since it can be glued. Once you remove that plastic cover, you will be able to see a screw holding the rest of the handle assembly to the door. Remove the screw. This should allow the entire door panel to be removed. You will need to push the panel up so it will disengage from the window opening. Good luck
