Go Back   Automotive Forums Car Chat > Toyota > 4Runner/GX470
Old 05-12-2004, 05:21 AM
90hbvtec's Avatar
90hbvtec 90hbvtec is offline
98 ?
hey i jess bought me a 98 4runner limited with only 83,000 miles on it for 12G is that worth it..?..looks sweet..umm as for now i jess like 4runners...problem is i have no manual for this 4runner.. now having trouble on doin stuff like how to shift the 4wheel drive to make it work all 4 wheels, cant even find the jack on the SUV , can someone tell me where is the jack located. i have an ABS light on i dont know if that ABS light is suppost to be on?..is there a reset button.. ?.. also have other problems like ill be signaling to the right, signal is blinking then i press on the brakes it does that speed blinking as if one of the bulbs are gone it only does that when i press on the brake but if the brake is off then it signals fine?..need help on that same goes with my reverse light when i press on the brake while reversing one of the reverse light goes out then one of the turnging lights goes on..its weired..has anyone expericed the same problem i goin through now..please help me..thanks
tru sohc vtec......
d16z6,ractive intake,ractive wires,msd ignition system w/blaster2
obx headers,pacesetter catback, w/test pipe,arospeed bomb muffler,tockico illumina shocks,r1 coilovers,GSR blades rims,ebay short shifter, w/neuspeed bushings,neuspeed strut bars front n back,ingalls camber kits altezza lights,indiglo gauges,proform shift light,integra center console..thats it for now...what else do i need...??ummmmmmm..TURBO..!!!!
Old 05-12-2004, 09:25 AM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: 98 ?
I can help with a couple...
There should be a card attached to the driver's side visor that details how and when to use the 4WD on your vehicle.
The jack is under the rear seat, passenger side.
The ABS light is not supposed to be on.
The blinking light means one of your bulbs is out. Have someone use turn signals and brakes and reverse and see what doesn't work.
For a manual, better contact the dealer.
Old 05-12-2004, 04:57 PM
98SR5 98SR5 is offline
Hello,
I put the shifter in Neutral then slide the smaller shifter to L4WD.
