Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 05-12-2004, 04:10 AM
perrenial151 perrenial151 is offline
rear brake caliper
I was trying to push the piston back into the caliper to make clearance for my new rotor and pads, but it won't budge. I used the clamp and broke it. I also drain the brake fluid out. That didn't help. I had no trouble with the front calipers.
What should I do?
Could the piston be rusted or dirty?
Is there a way I can take the piston out and clean it?
Buying a new caliper is the last thing I want to do
Old 05-12-2004, 06:25 AM
grncivicdhr's Avatar
grncivicdhr grncivicdhr is offline
AF Premium User
Send a message via AIM to grncivicdhr
your doin it wrong bro. i had that same problem.
heres how its done:
see the top of the piston on the caliper, it has those 4 notches. get a set of needle nose plyers and hold two of those notches that are across from each other and turn. the rear caliper on a 240sx is threaded so it needs to be turned down like a nut and bolt set-up. don't worry about the preasure you put on it earlier with that clamp, i proably did nothing to those threads.
Old 05-12-2004, 07:17 AM
SHO411's Avatar
SHO411 SHO411 is offline
Re: rear brake caliper
Damn Grn, never heard of that before, I've never done the rear brakes on a 240 before.
By the way Per151, I did a five lug conv on my S14 and I have the I think right side caliper sitting somewhere in my shelves, that and tons of other OEM stuff like seat belts, rear seats, whole wiring harness and ECU, etc. All these I pulled out cuz I can't use them with my project so might put them on e-bay soon.
Old 05-12-2004, 09:08 AM
J SPEC SilEighty's Avatar
J SPEC SilEighty J SPEC SilEighty is offline
Send a message via AIM to J SPEC SilEighty
haha yeah when i was changing my brake pads I was using a c-clamp to try and push the piston back in. i tightened that thing as much as i could and the piston wasn't budging. i finally checked the fsm and found out that it was threaded. this was the first caliper i had ever seen set up like that. when you are gripping the notches with the plyers, make sure you have a good grip on it when turning because the plyers can slip off and scratch the piston.... i did it a couple times. it also requires a bit of force to turn the piston, but it will turn.
Old 05-12-2004, 10:51 AM
SHO411's Avatar
Screwed brake pistons, thats a first, good thing I've swapped the Z32 calipers, will never have that problem, now if I can only finish the damn project before Sept.
Ain't this the pretiest motor or what?
Fines are the fee you pay for the privilege of driving as fast as you want
