Old 05-12-2004, 02:09 AM
nalej50 nalej50 is offline
Send a message via AIM to nalej50 Send a message via Yahoo to nalej50
Finding rims that fit
great site yall,I'm Jon & am in the process of experimenting with my car as a lowrider. I recently thought i found 15" 100 spoke wire wheels that fit my 1993 park av, but they stick out slightly. Sum1 told me the rims i have are "standard". Are there any wire rims that can actually fit on a park av or am i doomed from the start?Any help would be great!!
Old 05-12-2004, 06:23 AM
tman's Avatar
tman tman is offline
Pimpin' ain't easy
Send a message via AIM to tman
Re: Finding rims that fit
find a wheel with a 5 lug 115 mm backspace, and your good to go.
Old 05-12-2004, 12:15 PM
rotaran's Avatar
rotaran rotaran is offline
Send a message via MSN to rotaran Send a message via Yahoo to rotaran Send a message via Skype™ to rotaran
Here some ideas:
Mike
1991 Buick Park Avenue
1995 Ford Fiesta
Waghaeusel/Germany
Old 06-18-2006, 01:39 AM
Cntrysthbst Cntrysthbst is offline
Send a message via Yahoo to Cntrysthbst
Quick question, I have the 15" rims. I have a 92 Park avenue - not ultra. Can I put the 16" rims on it that come from the Ultra? Will this affect anything? Including the speed-o-meter? If it does can I replace the dash with an Ultra's dash? Just trying to get the car to hold the road better. Thanks!
Old 06-18-2006, 02:10 AM
tman's Avatar
Pimpin' ain't easy
go to tirerack.com and put in your current wheel and tire size, and the wheel size your going to. They'll tell you the updated tire dimensions so you can order the same overall size, you follow what I'm saying? Increase wheel size, the tire size shrinks.
You can also look up what the factory 16 inch wheels had on it to, go to tirerack.com and pretend like youve got the ultra and it'll give you the adjusted size.
Old 06-22-2006, 03:45 AM
Thanks Tman! Good site!
If I picked up 4 16 x 6 rims with tires from an Ultra can I just switch them out? I just want to double check to make sure cause from what that site said it looks like 92 PA's can take both the 15 and 16" rims. And last, will this affect my speed o meter? Thanks again!
Old 06-22-2006, 09:30 AM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
While on the topic, would a Bonneville rims fit 85-90 PA/Le Sabre?
I have alot of gold trim on mine and want to use the honeycombed Bonneville one's in gold, I think it would look sharp.
Old 06-22-2006, 03:06 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Thumbs up Re: Finding rims that fit
All of the GM cars of the 80’s listed below, use the 5 on 115mm (4.527") wheel.
Buick - Century, Electra, LeSabre, Regal, Riviera (some) '83-'89
Cadillac - Allante, most others '84-'89
Chevrolet - Celebrity '85-'89
Oldsmobile - Regency, Ciera, Cutlass, Delta 88 '84-'89
Pontiac - 6000 '83-'89- Bonneville, Grand Am '86-'89
Also, I am pretty sure that about all the 90-05 FWD Bonneville, LeSabre, Park Avenue, Monte Carlo, Regal, Cutlass and Grand Prix are interchangeable. Some of the newer ones have 17" wheels; however the hub bolt pattern are the same 5X115mm.
This is not an advertisement for Tire Rack, just passing on some suggestions and good deals;
Check out the Kazera KZ-T 18X7.5 for $129.00 ea closeout. Click on the wheel size to see them on the PA. Upgrade Garage Regular price of these wheels were, $449.00 ea! This is the most "wheel for the money", I have ever seen!! They look good on the PA or LeSabre.
Recommended tire size: 225/45YR18 Yokohama AVS ES100 $143.00, a very good tire for the money!
Here is another option; Custom wheels & tires @ Tires Delivered
Old 06-22-2006, 03:50 PM
wrightz28's Avatar
Meh, looks ok on that style body but i dunno about mine, the boxy predecessor.
Old 06-23-2006, 06:38 AM
Thanks!
