Go Back   Automotive Forums Car Chat > Honda > Wheels/Tires/Suspension
Wheels/Tires/Suspension All the handling help you need. No matter what Honda/Acura you drive.
Old 05-11-2004, 10:30 PM
boosted k20's Avatar
boosted k20 boosted k20 is offline
Civic struts in integra? Help!! jackassi
hey i just placed a bid on ebay for a set of FRONT bilstein HD struts for a 96-00 civic. Will these fit on a 97 integra? Once again these are only for the fronts. I was check n on some sites and i found out that the KONI reds will fit on the 92-00 civic and the civics from 92-95 have the same set up as the 94-01 integras. so im assuming that the fronts for the 96-00 civic will fit on my teg. is this right?
thanks
www.MEDIUMRACING.com
Old 05-12-2004, 01:56 AM
BullShifter's Avatar
Re: Civic struts in integra? Help!! jackassi
They should fit, but the valving might be a little weaker.
Old 05-12-2004, 10:53 AM
the struts are the heavy duty ones (HD). they should be able to handle the neuspeed race springs right?
Old 05-12-2004, 11:13 PM
Ok but Civic's & teg's don't weigh the same so the valving might be weaker no matter what strut it is.
Old 05-13-2004, 12:50 AM
Ricochet's Avatar
Ricochet Ricochet is offline
Banned
They'll fit but Integra's 1.8 engines weigh more than Civic engines, so they'll be stiffer, holding the car's nose higher in the air.
Old 05-16-2004, 06:57 PM
loesch8102's Avatar
loesch8102 loesch8102 is offline
Send a message via AIM to loesch8102
What about the brake lines? Do they attach to the struts in the same location?
