Go Back   Automotive Forums Car Chat > Mazda > RX-7
Old 05-11-2004, 10:15 PM
26B_600HP 26B_600HP is offline
Send a message via AIM to 26B_600HP
Really Weird Question
I have been looking up more on the motors lately and read a post about boring out a rotary. I had a theoretical question for you guys. Does changing the combustion chamber recess size change the engine at all? It seems to me that it would. If bored out there could be more air pushed into the engine. Is this logical?
Old 05-11-2004, 11:45 PM
MBTN's Avatar
MBTN MBTN is offline
Send a message via AIM to MBTN
Re: Really Weird Question
Boring out a rotary engine? No such thing. Perhaps you have this confused with porting.
Old 05-12-2004, 12:56 AM
DevoutWankelist's Avatar
DevoutWankelist DevoutWankelist is offline
Send a message via ICQ to DevoutWankelist Send a message via AIM to DevoutWankelist
I think he means machining out the recess on the surface of the rotor?
BAH!, went to change my sig and forgot what I was supposed to put here. . .
Old 05-12-2004, 01:58 AM
flex339's Avatar
flex339 flex339 is offline
Send a message via AIM to flex339
if you could do that your compression would drop.
Old 05-12-2004, 11:08 AM
MBTN's Avatar
Oops my bad. Yeah that's not exactly a good idea.
Old 05-12-2004, 11:39 AM
Yeah I meant the recess on the rotor. It was just a thought I had. So changing the size on it at all it bad for performance? What if it were possible to decrease the size then? I am speaking hypothetical.
Old 05-12-2004, 12:14 PM
MBTN's Avatar
I guess it could theoretically increase compression, but then it would change the "shape" of the combustion chamber. I think it's there because it needs a "concentrated" place to combust.
Old 05-12-2004, 01:39 PM
Ok I was just thinking of something, because in an old post someone was talking about boring out a rotary and it got me thinking.
Old 05-12-2004, 03:08 PM
Soyo's Avatar
Soyo Soyo is offline
Send a message via AIM to Soyo
there he goes with the boring out a rotary again...
1989 RX-7 TII --- Just got rebuilt and street ported
RB 3" dual exhaust, BNR stage 1 modified factory turbo, FCD, S-AFC II,
720cc secondaries, Aftermarket Turbo inlet duct w/K&N, Hawk HP+ pads
HKS Blow-Off Valve, Stainless brake and clutch lines
Old 05-12-2004, 05:31 PM
I never asked about it before Soyo, I was just thinking how to get more displacement, compression. Whatever it is to increase performance.
Old 05-12-2004, 10:35 PM
Soyo's Avatar
I meant you said it in the first port, then they said you can't bore it, then you just said it in the post before mine... rotarys aren't displacement engines really, bout all there is to it
Old 05-13-2004, 01:38 AM
flex339's Avatar
to truely bore out a rotary you would have to over bore the rotor housing which would make it junk and find overbore rotors to match the the housings that now serve no purpose.
Old 05-13-2004, 11:08 AM
yeah I know, never plan on doing it just having a thought in physics class about it. So the only thing to do to an engine when its apart is port it. Right?
Old 05-13-2004, 03:41 PM
Soyo's Avatar
yea, heres a page that will give you info on ports if you need it http://home.iprimus.com.au/bluey3/portsPage/ports.htm
Old 05-13-2004, 09:14 PM
flex339's Avatar
you can upgrade the seals inside the engine and you can upgrade the rotor housing to third gen specs.
