Crazy possesed ranger
Hi there! I have a possesed ranger. Please help... I tried to start my truck today and when it started it continued to try and start over and over again. So i turned to key off and took it out and the stupid thing was still trying to start. I tried to pop the clutch to stall it but it wouldn't die... this went on for about 5 minutes... can you please help me... I live in a small towm and I can't get it to a mechanic to fix it.... Thanx for any help you can give....
Re: Crazy possesed ranger
Sounds like your ignition is broken. Either that or the starter is going out. But it's most likely your ignition.
"I used to have a handle on life, but then it broke off..."
This problem is in the Starter Relay. I had the same problem in my 1986 Ranger. If you thump on the top of the relay with the handle end of a screwdriver you can get it to stop. It will come back again and again. The only permanent solution is to replace the relay.
