Old 05-11-2004, 09:50 PM
george536's Avatar
george536 george536 is offline
Octane booster?
I was lookin around my mitsubishi dealer and i saw this in the counter. http://www.brothersperformance.com/s.../nos12010.html
has anyone tried this? what does it actually do to your car?
Old 05-11-2004, 09:56 PM
Talon007's Avatar
Talon007 Talon007 is offline
Send a message via MSN to Talon007
Re: Octane booster?
It increases you Octane by 7 points, so if you run 94, then that makes it 94.7, totally worthless.
Chris Clark
www.Talon007.com
1990 Eagle Talon TSi AWD - In Progress
1993 Eagle Talon TSi AWD - Parts Car
1990 Eagle Talon ESi - Sold
1-800-VFAQ - Bookmark it, read it, use it
Old 05-11-2004, 09:58 PM
george536's Avatar
does it Cleans fuel injectors and combustion chambers?
Old 05-11-2004, 10:33 PM
helliviknow's Avatar
helliviknow helliviknow is offline
Send a message via Yahoo to helliviknow
Re: Octane booster?
looks like one of hundreds of useless products deseined to catch impulse buyers eyez.... i doubt it does much of anythin to help..
2006 Isuzu I-280 (Colorado/Canyon Clone)
AR 15" Baja's
K&N FIPK
Old 05-11-2004, 10:56 PM
george536's Avatar
what does high octane actually do for your car? does it give it better acceceleration or smoother ride or what?
Old 05-11-2004, 11:16 PM
Re: Octane booster?
high octane fuel takes more to ignite it. like when your running boost or nos or whatever with too low of octane the fuel can ignite b 4 its posed to and causes detonation.. basically bye bye engine.. has to do with compression i think.. im not completly sure but i think its sumthin like dat
AR 15" Baja's
K&N FIPK
Old 05-12-2004, 12:47 AM
george536's Avatar
so higher octane the better?
Old 05-12-2004, 01:46 AM
Re: Octane booster?
well its not really wether its better or not.. its wether u need it or not.. higher compression = higher octane... so like a turbo car needs it.. on the other hand i remember my dad used to have a shitty lil cougar that ran like shit on everything but 87... so its not always better to use higher..
AR 15" Baja's
K&N FIPK
Old 05-12-2004, 03:22 AM
AmericanEagle's Avatar
AmericanEagle AmericanEagle is offline
Send a message via AIM to AmericanEagle
Re: Octane booster?
Octane is the level of anti knock characteristics.
Knock inside the engine is caused by detonation or pre-ignition and usually one can cause the other.
Higher octane allows you to run more advanced timing, more boost or a leaner mixture before you start running into detonation.
For a stock DSM 92+ is recommended for best performance. But if you run lower octane the ECU will adjust until it no longer reads excessive knock.
1997 Eagle Talon TSI AWD A/T "Never Lift To Shift"
Injen Filter - Forge Motorsport BOV - Magnecor 8mm Race wires - NGK BPR7ES - Apex'i N1 - Joe p MBC - Modified Dejon "L" Pipe
Old 05-12-2004, 03:36 AM
Re: Octane booster?
yeah what he said..
AR 15" Baja's
K&N FIPK
Old 05-12-2004, 04:49 PM
BoostedSpyder's Avatar
BoostedSpyder BoostedSpyder is offline
Send a message via MSN to BoostedSpyder Send a message via Yahoo to BoostedSpyder
Re: Re: Octane booster?
too bad 91 is the highest in so cali...
