Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 05-11-2004, 08:22 PM
Jszy Jszy is offline
b16a head for ls/vtec
I want to find some prices for a b16a head for an ls/vtec setup. Does anyone know any good places to buy just a head for a motor? I know all of the good jdm swap sites, but I am looking for just the head and ecu. Is ebay the only route?
Old 05-11-2004, 10:35 PM
boosted331 boosted331 is offline
Junkyard.
Old 05-12-2004, 12:22 PM
Tranzlogic Tranzlogic is offline
Send a message via AIM to Tranzlogic
Re: b16a head for ls/vtec
yeah go salvage yard..try not to use ebay unless you fail everywhere else as per some stuff on there is sketchy....look for a GSR head too alot fo times there around the same price and that will broaden your search ...
try car-part.com for the salvage search
Old 05-12-2004, 01:06 PM
IntegraB16 IntegraB16 is offline
I don't know where you guys live, But there isn't a single junk/salvage yard in the entire state or Oregon that has a B16 or GSR head just laying around. Infact, I called them and they are all on back order. I would say your best bet is to go to a local performance type shop and order one, or go online.
Old 05-12-2004, 02:02 PM
I see....does anyone know if I will have a problem putting an obd1 or 2 gsr head on my obd0 1990 integra ls? Wont there be more wiring issues then using the b16a?
Old 05-12-2004, 05:15 PM
if you were getting a harness and ecu anyways it wouldnt matter...insted of the b16 ecu and harness you would just opt for the p72
Old 05-12-2004, 06:17 PM
scallywag scallywag is offline
Re: Re: b16a head for ls/vtec
Actually ebay can be a great place to find such things, you just have to know what you are looking for. usually priced pretty good to. you can find b16a heads on ebay for $500 and up depending on how much has been done to it. One store that sells on ebay sells b16a heads straight from japan, with only 30k on them, and will do the oil tap for you for an additional fee, and will do other things, such as port and polish, 5 angle valve job, etc. The key to shopping on ebay is to know exactally what you want, and know someithing about the product. Just shop smart, if it is too good to be true, it probably is. I bought my 96 ls off of ebay last summer, and I just bought a 96 gsr off ebay this week, I go to pick it up this weekend. You can find good deals, you just need to know how to shop. But if you can find a shop near by that sells them for a good price, that could be easier.
Old 05-12-2004, 08:06 PM
But wouldnt that mean that if I went with the b16, I would not have to replace the harness....I would jsut have to wire up the vtec, wouldnt that be alot easier?
Old 05-12-2004, 11:45 PM
95TegSE's Avatar
95TegSE 95TegSE is offline
To my knowledge, the only thing OBD specific on the head are the injectors and distributor. Find an OBD-0 VTEC distributor, injectors, and ecu and you'll be set to go. You'll just have the wire the VTEC to the ecu.
From the foothills to the bay, it shall ring, as we sing,
It shall ring and float away; Hail, Stanford hail! Hail, Stanford hail!
