Go Back   Automotive Forums Car Chat > Dodge > Stratus
Old 05-11-2004, 08:19 PM
iceman33 iceman33 is offline
Brake caliper question
Hello,
I changed out the brake pads yesterday on my 1995 Dodge Stratus. I bought the car used. Apparently, someone previously stripped out one of the bolts and the hole the bolt goes into on one of my calipers. For now, I "superglued" the bolt in, but for a temporary fix. My question: Does anyone know if they make a heli-coil that small, so that maybe I could tap the hole out and insert the heli-coil so that the bolt will hold???
Or, If anyone knows a better way to fix it, let me know please.
Old 07-02-2004, 11:31 AM
chadc chadc is offline
Same problem
I have the same problem. Did you find any answers?
Old 07-05-2004, 02:44 PM
No, I still haven't found a "real" solution. The super glue didn't hold, so I took out the bolt again and J.B. welded it. I don't know if it will hold or not. The only other thing to do is to buy the whole part that holds the caliper on.
Old 07-05-2004, 02:49 PM
knucklebuster2 knucklebuster2 is offline
Motormite ( Help!) makes oversized caliper bolts which cut new threads for many problem vehicles. Check with your local parts store if they make a bolt for your application. If not, I'm sure you should be able to find a Heli-coil that would repair the thread. A good parts pro would be able to tell you the thread size of the OEM bolt. If you have time, I can respond tomorrow with all the info. You just have to let me know if it was the front or rear caliper (if applicable.)
Old 07-06-2004, 10:33 AM
Re: Brake caliper question
Hey, it's the front left caliper (drums on back). I would appreciate it if you could get me that information on the size heli-coil and tap I will need. Thanks.
Rob
Old 07-06-2004, 06:21 PM
Motormite doesn't make a bolt for that application. The OEM thread size is 8MM X 1.25. The Heli Coil kit is part # 5546-8. The kit comes with the tap, drill bit, inserts and insertion tool. Should be fairly easy. Just drill straight! Good luck!
Old 08-06-2004, 06:19 PM
ozziepartsguy2003 ozziepartsguy2003 is offline
There is a product on the market called "time-sert" Kind of like a helicoil, but 100% permanent, helicoils with occasionally back out. With a time-sert you'll never have to worry about it again, unless some klutzy tech manages to cross thread the bolt again. Find a local machine shop or garage that uses them. Buying your own is out, you need to get a kit for each size, the average cost on the kits is 80 bucks I believe. I've used these on aluminum engine blocks, they work.
I do my own brakes, never crossed a bolt yet.
