Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 05-11-2004, 08:01 PM
arvtoyota arvtoyota is offline
Question 95 Screeching sound on reverse gear engage
Dear all
Since yesterday, I have started to encounter a strange issue on my toyota camry 1995 LE. As soon as I put the car in reverse gear, i get a whining noise, which dies down as soon as the gear shift is complete. I can hear a very mild screech again, when my car shifts from 2nd to the 3rd gear. My car is automatic transmission, has 103K miles on it and just 3k miles ago I had got the transmission oil changed.
I took the car to 2 mechanics, and both said all they can say is that " there is something wrong internal to the transmission - a worn clutch plate maybe". Also, they needed to open up the transmission, and will be able to figure out the issue only then.
I have really maintained the car well, and I feel before i pay in money just to open up the transmission , is there any way i can verify the problem atleast in some other way.
Your input is much appreciated.
Thanks
Andy
Old 05-11-2004, 08:39 PM
Joe W Joe W is offline
Re: 95 Screeching sound on reverse gear engage
Unfortunatly the only other way to verify this is when it won't move.This is a fairly common failure warning.
Old 05-11-2004, 08:54 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Noise from a transmission is nature's way of telling you something's wrong. Get it fixed before you are stranded somewhere.
Old 05-12-2004, 02:25 PM
Thanks guys for your helpful advice. This has started to happen only 2 days ago. i have 2 follow up questions -
1. How safe is the car to drive on the highway, based on the condition i described. This is because my mechanic is around 18 miles away from where i live.
2. Any ideas - would a transmission flush help, or is it a physical issue with the transmission - bearing, clutch plates etc.
Any help is really really appreciated.
Old 05-12-2004, 09:01 PM
Brian R.'s Avatar
Resident Chemist
Sounds like a physical problem to me. Don't mess with it, don't flush it. Get it fixed. It will drive for a while, you just can't tell how long.
