Old 05-11-2004, 07:31 PM
MaxCamaroZ28's Avatar
MaxCamaroZ28 MaxCamaroZ28 is offline
2000 Grand Am SE Front Brakes
Hey, i was changing the brake pads in my grand am and got the rotor turned and when i went to put in the new pads i couldn't because of the cylinder like thing in there which doesn't give me enough room to put the caliper back on the rotor. I tried bleeding the brakes and turning on the car and all that great stuff but it just sits there like a rock, i'm really close to just putting on the caliper without the pads and driving it to a mechanic to do it right.
Old 05-11-2004, 08:57 PM
justin0717 justin0717 is offline
Re: 2000 Grand Am SE Front Brakes
The piston is stuck out? Thats what i get from your explination. I had a similar problem, i just used a little extra force and some grease and wd-40 and shoved the piston back in (this was after i drained the lines-the piston wasnt just forced out by brake fluid, it had gotten stuck out, im guessing from sitting for a while). Hope that may help you.
Old 05-13-2004, 11:30 AM
gm-andy gm-andy is offline
If you put the old inner pad back on,and just crack open the bleeder screw, usually a c clamp will get in unstuck. As the pads wear, it will move out too far sometimes.
Good luck
Old 05-13-2004, 12:12 PM
Igovert500's Avatar
blue + red light magnet
Yeah, I always use a large C-clamp and a thin piece of wood or something to apply even pressure to the piston. Just make sure the bleeder screw is open a bit, as gm-andy said, or you can do damage to your master/slave cylinders.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 05-13-2004, 12:31 PM
CarSuperfreak's Avatar
CarSuperfreak CarSuperfreak is offline
Send a message via AIM to CarSuperfreak
and make sure that the piston is going into the bore straight! clamping down on even a slightly tweaked piston can easily cause it to crack. happened at the shop where i worked at. needless to say the guy was more careful from then on out, after having to replace a caliper at his own expense
Old 05-13-2004, 12:56 PM
Slade901's Avatar
Slade901 Slade901 is offline
Banned
You don't have to open your bleeder valve. It would be better to invest in a tool Disc Break Pad Spreader KD 3376 http://www.mytoolstore.com/kd/kdbrak07.html
It is available at your local autoparts store. It would make your brake pad replacement very easy.
