Old 05-11-2004, 06:50 PM
JJ122 JJ122 is offline
Need Help!!
Help
My camaro has gone through 3 window motors in a year. is there something wrong with the windows? Is there some way to retrofit a bigger motor it the space?
and how do you get to the motor when I take off the door panel there is a metal sheet there how do you get around them?
thanks for the help.
'93 Honda Del Sol Si stock (AT)
Old 05-11-2004, 07:15 PM
DaMoNe6969's Avatar
DaMoNe6969 DaMoNe6969 is offline
Re: Need Help!!
It sounds like either you are cheapin' out and getting a generic window motor *go get one from GM
Or your window tracks could be binding up causing a lot of unneccasary stress on the window motor.. Check, clean, and lubricate all of your window tracks.. Clean the wiring harness connector with some electrical cleaner..
hmm.. all I can suggest
Where are you gettin' your motors from?
Im not sure how to get to the motor.. Ive never done it on a 4th gen..
1991 Camaro Z28
Old 05-11-2004, 08:30 PM
housy_bigmike housy_bigmike is offline
Send a message via AIM to housy_bigmike
Re: Need Help!!
Click on this great site for more info and pictures of the door panel removal. Click on the right hand side under R&R power window motor.
http://shbox.com/1/4th_gen_tech1.html
Old 05-11-2004, 08:51 PM
Re: Need Help!!
someone posted that for me - details how to remove the door panel
Old 05-11-2004, 09:22 PM
ewh442 ewh442 is offline
Re: Re: Need Help!!
get a gm motor, remove door panel, remove most of the tracks, remove speaker (if it's like a bird) do some stretches and twist your arm just right and it'll come out. by the way the door is fiberglass so your arm will get itchy longsleeves help. almost lost a finger when a regulator unloaded on my hand once, had surgery to repair tendons and remove bone chips so BE CAREFUL!! hope i didn't scare ya.
Old 05-11-2004, 09:45 PM
DaMoNe6969's Avatar
Re: Re: Re: Need Help!!
Oh if only someone warned me about that before my first motor change! lol
Mind you, my injury wasnt as bad as yours, it still woulda been nice to know before hand
1991 Camaro Z28
Old 05-11-2004, 11:56 PM
thanks for the help. I'll check those areas
Old 05-12-2004, 12:16 AM
tacoma man tacoma man is offline
Re: Need Help!!
if some one would have said something earlier
id still have my pointer finger.
Old 05-12-2004, 09:03 PM
regulators
glad to know i'm not the only one who was chopped up by a regulator! it was at the dealer where i work, so luckily they took good care of me. the motor was on cousin's black ram air, about a year later my wifes quit on her black bird, yes i was nervous but i did it. i drilled two holes in the regulator arms and used bolts w/ nuts to keep them from moving, worked well. last two days have been baffled by a hot no start problem on a BLACK 89 350tpi TA, do you see a trend here?
