Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 05-11-2004, 03:14 PM
JacksonJoker JacksonJoker is offline
Mechanic Question
I was driving my 92 240SX done the interstate and it just quit. It will crank but will not run. Have checked fuel pump, it's good. Seems to be firing, but will not run. Any ideas as to what could be the problem? Basically use it to drive back to work, so I don't want to spend too much on the fix.
Old 05-11-2004, 03:25 PM
vsiev vsiev is offline
Send a message via AIM to vsiev
Re: Mechanic Question
there is gas in the car right? Also have you tried jump starting it? It might be many things but I would try the simple ones first. Check your gas, jump start it, etc.
Hiya...
Need a FSM? Hit me up I'll send it to ya for FREE!
I only have the 91-98 240sx, s13 ca18det, and s14 sr20det FSM
Sorry no 89-90 yet....
Mods:
Tein Flex with EDFC
Hotshot Header
R32 GTR Seats
Advan SA3 16x7 16x8
Apexi Dual N1 Exhaust
Silvia Front End Conversion
Digital Climate Control
Nismo 2-Way LSD
Injen Intake w/ CAI
Old 05-11-2004, 07:19 PM
SHO411's Avatar
SHO411 SHO411 is offline
Didn't give enough info.
In saying it cranks, do you mean, the starter turns the engine but wont start the car or do you mean the car starts but will not move????????
If the engine turns, then you fuel filter or injector could be blocked. Boot leg way of testing it,
-unplug the hose right after the filter and turn the key to semi on, if no fuel, then there is you problem.
-if not, unplug the return line after the injectors (be careful of fire risk so put a thick towel), see if fuel is running.
If there is spark, and the car starts but will not move, you clutch or TQ conv could be messed up, depending on Manual or AUTO.
But thats all I can come up with with the little info you left for now.
Old 05-11-2004, 07:39 PM
Broke_as_****'s Avatar
Broke_as_**** Broke_as_**** is offline
It is probably something simple like a sensor disconnected itself or what have you. KAs are known for their dead solid reliablity so the chance that some major went wrong is very remote.
Check the entire engine bay very carefully for anything loose or unplugged. Failing in that, since the engine cranks and seems to be firing, the fuel delievery as said before is suspect. Just keep tracing it back from working systems until you find the problem.
1989 240SX Fastback. . . . . . . . . . . . . . . . . . . . . . . . . . . 1995 300ZX Twin Turbo
Warning: Objects in mirror aren't as fast as they thought they were.
Old 05-11-2004, 10:28 PM
J_Spec_NiTeMaRe's Avatar
J_Spec_NiTeMaRe J_Spec_NiTeMaRe is offline
Send a message via AIM to J_Spec_NiTeMaRe
Ahhahahah are you kidding? Anyone who has owned a 240 knows how unreliable they are. If you never have it break on you, you're extremely unlucky...it's part of the experience of owning that car.
Old 05-11-2004, 11:28 PM
I've owned my 89 Fastback for a couple years now, been driving it back and forth to work about 20 miles both ways every day for a while...and been beating the crap out of it on the weekend fairly often, and I've never had any problems that were more then normal wear and tear. KA is a solid motor, maybe the DE less so but at hard 195K on the odo with the original engine, I can't bring myself to complain.
Old 05-12-2004, 07:46 AM
SHO411's Avatar
By the way, if your TPS sensor is gone, your car will start, but the ECU will not be able to match the correct air fuel mix with no feedback from the TPS, this will in turn make it shut off the car.
I just cut a whole in one of my clients exhaust and also my J30 right before the cat cuz they wouldn't stay on, the cat was stuffed up. It could be a million diff reasons, got to be more precise with the discription.
Old 05-12-2004, 10:43 AM
SR20DETpower SR20DETpower is offline
Banned
Send a message via AIM to SR20DETpower
check your ignition system, this sounds like what it is.
sometimes u can just be driving down the road and all the sudden it quits and won't start again, that is usually an ignition problem.
I would replace all the ignition parts before messing with anything else, its a good thing to do anyhow.
Old 05-12-2004, 10:47 AM
SHO411's Avatar
he said he has spark, that would rule out ignition, but check anyway.
Ain't this the pretiest motor or what?
Fines are the fee you pay for the privilege of driving as fast as you want
Old 05-12-2004, 11:30 AM
BlackBlur's Avatar
BlackBlur BlackBlur is offline
Banned
Send a message via AIM to BlackBlur
I dont know bout the 240s but my Eclipse did something similar and they said it was my auto shut off-relay thing, near the windshield side of the engine bay. Didnt fix it but a new computer in 'er did! Junkyard...wootwoot
Old 05-12-2004, 11:52 AM
KenOhki2112's Avatar
KenOhki2112 KenOhki2112 is offline
Send a message via AIM to KenOhki2112
Yeah, mine needed a clutch when I bought it, but my 240 has yet to give me any matinence suprizes. it only has 108K miles though. I drive it really hard too =(
-KenOhki2112
Old 05-12-2004, 04:56 PM
nissanfanatic nissanfanatic is offline
240SX Guy
Send a message via ICQ to nissanfanatic Send a message via AIM to nissanfanatic Send a message via MSN to nissanfanatic Send a message via Yahoo to nissanfanatic
Check the cap, rotor, and plugs.
-Cory
1992 Nissan 240sx KA24DE-Turbo: The Showcar
Stock internals. Daily driven.
12.6@122mph
496whp/436wtq at 25psi
Old 05-21-2004, 08:07 AM
Should have been more specific. Should have said it will turn over fine(crank), but will not start(run). Plenty of gas, unhooked the fuel system and it primes just fine. Checked and it seemed to be firing just fine. Have gone over the engine thouroughly and found nothing that was disconnected. Am going to start more troubleshooting this weekend and will check everything again. Thanks for the help.
Old 05-21-2004, 08:44 AM
SHO411's Avatar
thats a tough one, all the usual culprits are working fine. Unplug one injector see if it is squirting anything. By the way, just because you can see fuel doesn't mean it is in pristine condition, the volume may not be enough, on the spark if you can see a spark at the plug that usualy works, don't hold the plug or plug wire with your bare hands, use some insulated thongs. Trust me 10-40 thousand volts will not kill you cuz the amps are weak, but it stings like shit. Double check on your intake, your TPS sensor and MAF sensor.
