Go Back   Automotive Forums Car Chat > Geo > General Discussion
Old 05-11-2004, 02:33 PM
insomica insomica is offline
Send a message via AIM to insomica Send a message via Yahoo to insomica
Install a Tach on a '94 tracker
Does anyone have a pic of where to put the wires and how to run it though the firewall? Also what is the Redline for a "4cylinder 1.6L I-4 MPI"? I would like to know how to install one before I spend $50 on a Tach.
How much does a good Tach cost? I saw some at Autozone for about $30 -$50. Does that sound about right?
Old 05-12-2004, 03:21 AM
1995 geo tracker's Avatar
1995 geo tracker 1995 geo tracker is offline
look around ebay for a gauge cluster for a tracker that already has the factory tach , i seen them go for cheap and they will plug right in
Old 05-12-2004, 01:37 PM
Re: Install a Tach on a '94 tracker
I'm not to crazy about taking out the gauges. I'm new to all of this and I think thats over my head. Maybe if their was a "how to" I might do it.
Old 05-13-2004, 01:29 AM
in the amount of time that it would take you to put in the tach you could swap out your gauge cluster , grab a haynes manual , it will tell you step by step how to do it , but if you still want to use an aftermarket tach the manual will help you locat the wires you will need to splice into
Old 05-13-2004, 02:29 AM
how are the gauges attached?
Just plug in and out? I'm guessing i would have to install the green wire to the (-) of the engine coil (witch i have no idea on where that is at)
Old 05-13-2004, 12:29 PM
yeah just a few screws and then just unplug it and plug the other one in
Old 05-13-2004, 02:32 PM
Do I have to install a wire on the egnine coil?
Old 05-14-2004, 12:58 AM
not for the factor dash cluster
Old 05-14-2004, 02:20 PM
Sounds good, I'll start looking on eBay for a cluter.
Junkyards around here don't have much. They are all striped of usfull parts.
Old 05-15-2004, 03:35 AM
i have a 95 tracker with a blown engine so if you ever need parts let me know , i don't have the cluster you need but if i did i would sell it to you , but if you need anything else let me know , it got parked with a brand new top , new tires , and alot of new factor parts
Old 05-15-2004, 02:55 PM
Do you have the frame that goes over the handle to keep it in place? It kinda looks like a pentagon. It's held on with one screw.
Passenger Side
What are you drving now that your tracker is blown?
Old 05-16-2004, 04:33 AM
can you give me a little better idea of what handle you are talking about, i am sure i have it just need to be clear on what you need
Old 05-16-2004, 02:17 PM
http://www.insomica.com/my/tracker/brokenhandle.jpg I took a pic of what is broken. If you have the handle part how much would it cost? (item+S&H)
The handle normal just hangs down and you have to pull it towards the egnine to get the door to open.
