Go Back   Automotive Forums Car Chat > Honda > Integra
Old 05-11-2004, 01:20 PM
rollingsuicide rollingsuicide is offline
sorry, but please help anyway
ok i read the faq thread but i couldnt follow that well. I just 16 and got a 91 integra ls. Im planning on putting a turbo in when i save up enough money. but id also like to get a better engine. I heard a stock ls engine with a vtec head was good. but is just dropping a gsr better. im sure this was asked many times before but itd be cool if u could answer one more time.
Old 05-11-2004, 01:27 PM
IntegraB16 IntegraB16 is offline
Re: sorry, but please help anyway
I'm sure others will disagree, but I would just drop in a GSR and turbo it.
Old 05-11-2004, 02:17 PM
i think im gonna go with the ls/vtec. my dads a mechanic so i know he wont half ass the job or anything. theres 133000 miles on the car so when the ls/vtec is shot ill either put a gsr in or just get a new car
Old 05-11-2004, 02:57 PM
kicker1_solo's Avatar
kicker1_solo kicker1_solo is offline
Send a message via AIM to kicker1_solo Send a message via Yahoo to kicker1_solo
it's funny how you ask for our opinion when you've already made up your mind. Good luck
2000 BMW 323IT
1954 Ford F100
With every post my penis grows smaller
Yakima Valley Truck Club Yakima Washington
Old 05-11-2004, 03:34 PM
kpsycho's Avatar
kpsycho kpsycho is offline
i think ls/vtec turbo is good but if i were you i would spend the money that would be spent on ls/vtec to build the block for boost then boost the hell out of it. much better that way imho.
Old 05-11-2004, 10:27 PM
00tegra 00tegra is offline
you would have to wrok the engine up to it if you wanted to go turbo and run anything over 6 psi. your best bet is to get a stock turbo engine and put that in.
Old 05-12-2004, 09:36 AM
shaunthebadass shaunthebadass is offline
Send a message via AIM to shaunthebadass
i would just go with the ls/vtec and turbo it because it already has the 9.2:1 compression ratio that would would desire running forced induction. if you were to turbo the gsr you would have to drop the compression fro its 10.1:1 to around the same as the ls already has, hence you save money there by going with the ls/vtec and you can easily pick up and ls block and vtec head for less than a gsr motor. also the ls/vtec setup is faster than the gsr. hope this helps
Old 05-12-2004, 11:01 AM
I think a lot of people forget some stuff about GSR blocks compared to the LS block. True you would have to lower the compression ratio, but the GSR has oil squirters that spray the piston to keep it lubed good, the GSR also has higher tolerences and can handle more boost, as well as being able to revv higher than the LS without having to upgrade the rods.
Old 05-12-2004, 01:32 PM
scallywag scallywag is offline
Re: Re: sorry, but please help anyway
If I am not mistaken when you do an ls/vtec, you get oil squirters as well, isn't that why you have to tap the oil? I may be wrong. Also GSR CANNOT handle more boost than an ls block. I don't know where you got that info, but it is incorrect. A GSR block can only handle 8psi well tuned, and has been know to be able to run up to 10psi with a mad good tune. the ls block can handle 12 psi with a good tune, and highter with a really good tune. Personally i wouldn't recomend going higher than 8psi on the gsr, and 12 on the ls, both well tuned. The gsr block cannot handle as much due to it's high compression pistons. Also the ls tranny is really turbo friendly as well. Either way you are going to have a fun car. If you are on a budget, then I say go ls/vtec turbo, you will get the most bang for your buck. But if you got the cash, then go vtec turbo.
Old 05-12-2004, 06:27 PM
ok, As fas as the oil squirters.. you could be right.. But what I meant with the GSR handling boost. I mean with lower compression pistions. Not stock. There is no way it could handle more on stock pistons.
Old 05-12-2004, 10:52 PM
ok my man integrab16, go boost both motors to 10psi and see which one blows first, obviously the one with the lower compression ratio
Old 05-12-2004, 11:37 PM
95TegSE's Avatar
95TegSE 95TegSE is offline
No, when you tap the head for oil, it's adding the necessary oil pressure to open the vtec solenoid. On VTEC engines the oil is routed through the block through a hole in the bottom of the head, hence the fact that you have to plug that hole when doing LS/VTEC.
From the foothills to the bay, it shall ring, as we sing,
It shall ring and float away; Hail, Stanford hail! Hail, Stanford hail!
Old 05-13-2004, 01:35 AM
You got that backwards! The motor with high compression pistions will blow first.
(QUOTE) I mean with lower compression pistions. Not stock. There is no way it could handle more on stock pistons.(QUOTE)
That is not really a fair statment. That is like saying hey my gsr motor can handle more boost than your ls, just let me go build the bottom a bit. Of course if the bottom of the gsr is built it will handle more than the stock ls bottom. Every thing set aside, I think the LS is a stronger block non the less. I could be wrong, but I believe I have read that. It would be nice if someone could clear that up.
Oh an I was mistaken about the oil squirters, as has been pointed out above.
Old 05-13-2004, 08:38 AM
yeah i def. wanna go ls/vtec but i read stuff about the r/m ratio suckin in ls/vtec and it shouldnt be reved high. is that something to worry about? and also if i do do this there will be a 133k miles on the block. if i put new parts in the will it be more unlikley to blow/drive better/lastlonger?
Old 05-13-2004, 10:45 AM
If you got the cash, I would suggest new rods, and pistons. 133k isnt really alot on a honda motor, but if you want to drive it hard, I would do that, becides then if you go turbo, you will already have a sumwhat built bottom, so you could boost highter. Look into eagle, and crower. If you do go turbo, look into getting forged low compression pistons. and go with forged rods as well. then when putting the head back on get a good aftermarket head gasket. All those things will make help you run higher psi. Good luck.
