Go Back   Automotive Forums .com Car Chat > Honda > Civic | CRX > '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV
Old 05-11-2004, 11:07 AM   #1
krstofer
Send a message via AIM to krstofer Send a message via Yahoo to krstofer
Question Headers and fuel rails and pipes... oh my.
Ok, I have read some of the links on the FAQ and did some searching on the forum, but my question is this:
Where do I start?
Personally, I started with the handling and braking, putting crossdrilled rotors, wider tires, and eibach springs (have them, but not installed yet).
I wanted to make sure the car could handle the extra power.
Now I am ready to move to the engine. What is the first logical step? ECU? Fuel Rail? Pipes? Header?
I have a B16Y8 96ex Auto Tranny. I want to start inthe most logical order so I don't blow anything and have to get a new engine when I am not prepared for it.
Thanks,
Krs
M3FU.COM
krstofer is offline   Reply With Quote
Old 05-11-2004, 05:39 PM   #2
snowman2005
snowman2005's Avatar
Send a message via AIM to snowman2005
Re: Headers and fuel rails and pipes... oh my.
umm 96 ex is d16y8 and what most ppl ill say i/h/e. intake, headers, exhaust. or if u have the money get a turbo and/or engine swap
snowman2005 is offline   Reply With Quote
Old 05-11-2004, 05:48 PM   #3
krstofer
oops, didn't realize I put the C in the D16Y8. :-) I was going through so many posts.....
Anyway, already I learned something new. I could not figure out what i/h/e/ meant and could not find the meaning so thanks.
I was going to start with the intake, so I got that right. Is it headers OR turbo or both? I was reading the turbo FAQ (i think) and I didn't get it. I think it was turbo replaces header. Is that right?
Not gonna do an engine swap, just a build of the one I have.
Krs
M3FU.COM
Old 05-11-2004, 06:11 PM   #4
snowman2005
right now on ur car i think might (be different with the d16y8 ) is an exhaust maniflod and the headers replace that to give u more power. for the turbo the turbo mounts up to a manifold(different one form the stock one). to get a turbo u do have to replace either the headers u put on tehre or ur stock manyfold. so if u were u id decide if id go all motor or turbo bc there is no point in buying parts that will end up gettign replaced
Old 05-11-2004, 06:22 PM   #5
kicker1_solo
kicker1_solo's Avatar
Send a message via AIM to kicker1_solo Send a message via Yahoo to kicker1_solo
there's so much more that you should do before going turbo, build the motor first.
2000 BMW 323IT
1954 Ford F100
With every post my penis grows smaller
Yakima Valley Truck Club Yakima Washington
kicker1_solo is offline   Reply With Quote
Old 05-11-2004, 06:53 PM   #6
GScivic7
GScivic7's Avatar
Send a message via AIM to GScivic7 Send a message via MSN to GScivic7
werd, forged pistons, rods, and resleeve the cylinders. Should help your engine handle a good amount of boost. Cams and a little headwork would help a lot too.
Empty Pockets Racing Member #1
GScivic7 is offline   Reply With Quote
Old 05-11-2004, 06:56 PM   #7
snowman2005
fvor turbo what kind of cams do u want soemthign agressive with lot of lift or what?
Old 05-11-2004, 07:17 PM   #8
GScivic7
GScivic7's Avatar
what you want to look for in a turbo cam is less overlap and duration. Since you are shoving air into the cylinders. You don't need the valves to be open for a long period of time.
Old 05-12-2004, 08:32 AM   #9
krstofer
I am not positive I will go with a turbo. I will do exhaust and intake first then see where to go from there.
The reason why this is confusing to me is most of the cars I've owned in the past were minimum 350HP. The civic is the least powerful car I have ever owned. I know about changing Exhaust, headers and carburators. the most powerful engine I was lucky enough to have was a v-8 460hp ford with a 4 barrel holley carb and straight pipes with glass-pacs.
Now I don't want to try to hit 460hp, but I need more that what the stock engine is pumping.
M3FU.COM
Old 05-12-2004, 09:13 AM   #10
snowman2005
yea thats alot of power the only way ull get close to the smae feeling of power in a honda is engine swap and a turbo. but im sure ull enjoy working on and driving hondas just as much as ur other cars
