Old 05-10-2004, 11:07 PM
JoeBobE218 JoeBobE218 is offline
77 c10 knocking
I just bought a 77 c10 with a 350. Its got about 175,000 miles on it and every once in awhile it sounds like it may be knocking. If it was knocking wouldn't it do it all the time cause my friends truck was knocking real bad all the time and it got louder as he gave it gas. My truck if i give it gas the knocking sound goes away. Can somebody please help me figure out what this is?
Old 05-10-2004, 11:49 PM
burnM's Avatar
burnM burnM is offline
Re: 77 c10 knocking
Fuel pump? Sometimes the fuel pump will knock so loudly that that some will mistake it for a cam problem. Could also be a crack in the flywheel. That's about all I can think of right now for an intermittant knock....
Does it only do it when first started? When it is hot? Only when cold?
1977 GMC Jimmy - daily driver-sitting on 33's and bedliner inside and out
1995 9C1 Caprice - winter beater
1994 Impala SS - newest project
1991 9C1 Caprice - (rip)
"There are two great problems in the world today; an ever-growing lack of common sense, and too many warning labels. Take away all of the warning labels and the problem will work itself out..." -B
Old 05-11-2004, 06:11 AM
It doesn't seem to matter if the engine is cold or hot. It just does starts making noise whenever it feels like it.
Old 05-11-2004, 12:52 PM
broughy84's Avatar
broughy84 broughy84 is offline
is it doing it under heavy load or when you are still. If it is doing it at heavy load you could be spark knocking.
Old 05-11-2004, 10:25 PM
I can only hear it when its idiling. I think i may have fixed the problem by replacing the spark plugs and wires. it runs a whole lot better now.
Old 08-17-2004, 02:31 AM
jramos1184 jramos1184 is offline
Cool 77 C10 knocking
you may want to try tacking off the valve cover and using a socket and rachet to tighten the valve springs up i'm going to warn you try not to get any trash in there and if you do decide to do that it is very messy
Old 08-17-2004, 08:42 AM
SpitAndDirt's Avatar
SpitAndDirt SpitAndDirt is offline
Re: 77 c10 knocking
Just an idea here...with that many miles, you could be looking at low oil pressure. As clearences wear, the oil has a more likely chance of escaping from around rod and main bearings, camshaft bearings, even through the lifters. It could be as simple as a new oil pump, requiring the removal of the oil pan. Or it could be the engine has had the crap driven out of it. As long as your using quality gas, and the engine has been taken care of, the logical thing is normal wear and tear. One last thing is that you should not be using the heaviest oil out there. I would recommend 10w40 mobil conventional oil. No additives or Motor Honey. And don't buy that High Mileage crap, personally I believe it's just a marketing gimmick. I have not seen any difference. But do what you need to. This has always served me well. Hope this helps -Chris
