Old 05-10-2004, 09:45 PM
jericho999 jericho999 is offline
Timing belt/bent valve
K heres the problem, i was driving my 1988 Honda Crx si and it just stalled so i took it to Honda and they sed the timing belt snapped, i get that fixed and then the car was running like shit, so i took it back and they sed one of the valves was bent from the timing belt snapping, so i took it to another shop to get a diff price and they told me it would cost like 1 g canadian, but then they sed if i took them just the cylinder head it would only be $280 heres my question how do i take the cylinder head off, like what do i take with me and stuff like that and also what else do i need to fix the car after there done with the cylinder head, like do i gotta buy new seals and stuff,
if anyone can help it would help alot.
Old 05-10-2004, 10:12 PM
Autocratic_1st_Gen's Avatar
Autocratic_1st_Gen Autocratic_1st_Gen is offline
Re: Timing belt/bent valve
short version, go buy a manual, you will need it
you will need a head gasket (get one for a 95 civic EX) $50
head bolts or ARP head studs (ARP are reusable, stock are not) $100
I think thats it.
i have a 91 Civic DX with 3x as much money in it as what i paid for it
i wish it was fast
here is my website
http://www.geocities.com/krustindumm/index.htm
Old 05-10-2004, 10:18 PM
4GZChatch's Avatar
4GZChatch 4GZChatch is offline
Send a message via AIM to 4GZChatch Send a message via MSN to 4GZChatch Send a message via Yahoo to 4GZChatch
Autocratic, I'm pretty sure that the D-series head bolts are reuseable, not stretch bolts.
What motor do you have? If it's the stock A6, you can toss on a vtec cylinder head. I would never pay to have head repairs done, because of the ready availability and inexpensiveness of replacement parts for these older motors. You can get them on ebay for around $80-90 USD, and if you can do the work yourself, you can keep the new timing belt, and get vtec. You'll need a new head gasket, but that's really it. You keep your dist, injectors, plugs, wiring harness, etc. It's also a great chance to change your water pump, oil pump, and front main seal. It's not too tough to do if you have any experience with it.
Remember: You can't spell Crap without APC!
Classic SE-R
GTi-R turbo setup
3" DP
U12 modified ECU
Hyperco GenII suspension
Progress sway
SAFC
etc. etc.
Old 05-10-2004, 11:40 PM
91hbman 91hbman is offline
Send a message via Yahoo to 91hbman
i just burnt a valve on my 91 hb dx and i bought a newer used head on ebay for 85 bucks shipped. be careful though make sure you ask if the valves in the new head are bent. i didnt ask and ended up with two bent valves. i reused the head bolts and have had no problems in the department. you'll want a new head gasket and might want to replace the intake manifold gasket. you can also just go to the auto store and ask for a new head gasket set, the whole set will include everything you need. if your leaving the timing belt on try to make sure you leave it on the cam gear. it will keep time that way.
Thanks for any of the help that anybody has offered. I try to do the same. And remember "It takes all kinds to make the world go round."
Old 05-11-2004, 10:43 AM
Re: Re: Timing belt/bent valve
I am 100% posative that they are torque to yield bolts, and while I would not recomend reusing them under any circumstances, I have done it, and it has worked for me, but I was willing to pull the head again if it didn't.
i wish it was fast
here is my website
Old 05-11-2004, 10:49 AM
KoRnSaQ KoRnSaQ is offline
Send a message via Yahoo to KoRnSaQ
ya, i would just get another head, you can usually get them for prety reasonable prices. then all you will need to get is a head gasket set, or you could get away with head gasket and vlave cover gaskets(but i reccomend getting the intake and exhaust gaskets to). It took me and a friend a days work to switch the head and have it running again.
KoRnSaQ
