Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 05-10-2004, 09:44 PM
sihondasracer's Avatar
sihondasracer sihondasracer is offline
Send a message via AIM to sihondasracer Send a message via MSN to sihondasracer
95 HATCH SOHC ZC SWAP ???????'s
my friends got the cash and for the sohc vtec zc swap and he wanted to to it untill the money for the H22...yea about the swap is everything workable and easy? beside swappin the ecu's and vtec stuff everything else is factory fit i.e exhaust flanges,sensors,tranny general things like that. oh and anyone who has done this swap...lemme know who it went its all the deciding factor's for the swap...
i live for the feeling i get when i downshift and feel the motor scream up to 8000 rpm and pull on any unsuspecting victim with the fury that an old hatchback should never have.
Old 05-11-2004, 10:19 AM
Tranzlogic Tranzlogic is offline
Send a message via AIM to Tranzlogic
Re: 95 HATCH SOHC ZC SWAP ???????'s
your not making any sence they way your typing ! were you originally doing a zc but now want to do an H22 or whats going on here ??? more info
Old 05-11-2004, 11:29 PM
doin the zc untill hes got the money for the H22,and yes i need typing school badly.lol
Old 05-13-2004, 01:16 AM
94tegRS's Avatar
94tegRS 94tegRS is offline
I got the DOHC ZC in my 94 hatchback. I had to rig my distributor since the ZCs were in the pre OBD's and the 5th gen civics are OBD1, but I saw a kid wiht a ZC in his crx of 4th gen style, and it had a extra sensor that was run off the exhaust cam(he had the DOHC as well) and told me that it was the CAS, which is what my ECU threw the code for when I had the ZC running. and the older style ECU's wont plug into the 5th gen harnesses anyways I dont think, my friend dad had a broke down old CRX where the ECU is under the seat, thought Id try it to se if I wouldnt throw a code with this ECU, but it wouldnt fit, maybe it was a old old CRX, not sure what year it was. I ended up taking a OBD1(2 works also) B series distributor, and youll eventually find a way that one hole lines up, and it bolts in, only thing is only one bolt holds it(no leaks yet though) and you have no timing adjustment, you also have to rotate the position of the plug wires 90 degrees CC wheen looking at cap. you can be sure thogh by when you remove the civic dist, look where the rotor is pointing, then put the new dist on, wherever the rotor is pointing move the wire from the cylinder the old rotor pointed to to where the new rotor points to and then finish the firing order(1-4-3-2 I belive)
current
-84 datsun 720 4x4(2nd time)-93 accord-90 camry V6-90 warrior-94 300ex
history:
-01 R1-04 daytona 600-94 teg RS-95 teg LS
-91 teg RS-92 teg GSR-94 civic CX hatch (3 times)
-94 civic DX-96 civic HX-97 Accord LX-72 superbeetle
-74 beetle-84 silverado-66 c10-74 maverick-78 280z
-84 200sx-86 tercel wagon-95 mustang V6
