Old 05-10-2004, 08:16 PM
Valero Valero is offline
Tach and Dwell Meter
Any help on hooking up the 2 wires of a Tach/Dwell meter to adjust/verify RPM ?
Old 05-11-2004, 12:53 PM
geozukigti geozukigti is offline
RPM's are based off of the pulses your ignition coil puts out(negative side). If you buy an aftermarket tach, and it doesn't have a 3cyl option, it won't give you the right RPM's.
Old 05-11-2004, 01:10 PM
Re: Tach and Dwell Meter
That's cool, the question still stands: How or where do you hook up the Tach and dwell on a 94 metro. My tach goes down to 4 cyl but I can easily (Mathematically) convert it to 3.
thanks geozukigti
Old 05-11-2004, 04:41 PM
Re: Re: Tach and Dwell Meter
Hook the tach's signal wire up to the negative wire on the ignition coil. I would still recemmond buying a proper tach.
Old 05-11-2004, 11:25 PM
insomica insomica is offline
Send a message via AIM to insomica Send a message via Yahoo to insomica
What is a "proper tach."
and where do you get one?
I want to install one in my tracker...
Old 05-12-2004, 10:06 AM
Ohh, your tracker should have a 4cyl engine in it. It'll work just fine then.
