Old 05-10-2004, 07:21 PM
gschretter gschretter is offline
Question Trying to find timing.
I bought one of those SEARS triming light with the adjustable timing knob on the back of the gun.
On a pre-1987 Chevy 350,
RMP 700
Vaccum Advance disconnected.
Hooked up to spark plug number one.
I have to turn the knob to 40 degree advance in order to have the timing mark at 0.
The engine runs great, runs on normal gas and stuff.
The idle is 450.
What am I doing something wrong ?
Thanks in advance.
Old 05-10-2004, 07:24 PM
xdelirious45x xdelirious45x is offline
Send a message via AIM to xdelirious45x Send a message via MSN to xdelirious45x Send a message via Yahoo to xdelirious45x
Re: Trying to find timing.
The idle could be a different problem then the timing. The low idle could be caused by low amounts of fuel being injected, a bad idle control module, or other things. I would just suggest you double check those before you reset your timing again.
good luck, im trying to rebuild a 350tbi so i'll probably have similar problems, lol
Old 05-10-2004, 07:29 PM
Re: Re: Trying to find timing.
No I set the idle to 450 for normal engine operation but I check the timing at 700 rpm as per the book.
Thanks.
