Go Back   Automotive Forums Car Chat > Honda > Integra
Old 05-10-2004, 07:03 PM
teamfour teamfour is offline
Engine revs up and down
When I start the car the idle goes real high for a few seconds. It then settles down but goes from idle to 2000 rpm in a pulsating rythym until you put it in drive. Hard to describe. Is this a sensor problem? The car is a 90 Integra LS.
Old 05-10-2004, 07:35 PM
IntegraB16 IntegraB16 is offline
Re: Engine revs up and down
It could be a vacuum leak.. Or there is another thing that could be wrong. Try this and tell me what happens. Take off the intake piping from the intake manifold and there should be two holes inside the throttle body on the side closest to the firewall. While the car is running plug the holes with your fingers and see if it stops loping. If it runs good I will tell you what you can do that might fix it.
Old 05-12-2004, 12:47 AM
Jdm_180sx Jdm_180sx is offline
Unhappy
ya i had an accord and i just slipped a bolt in the hole in the throttle body and it quit. (not to sure if its good for the car)
Old 05-12-2004, 08:50 AM
geojim geojim is offline
Mine did this one day after I was doing some routine maintenence. Idle was going up and then down. After looking, I had missed hooking the PCV line back up to the intake. Sounds like you could have a vacuum line that came off or is cracked.
Old 05-12-2004, 12:07 PM
Hey JDM, I hope that bolt don't come loose and suck into your intake Manifold. If you look under your throttle body there is a device (i don't know what it's called) it has 3 bolts holding it in. There are two hoses that hook onto it. Unhook the hoses and then unbolt it. Once you have it off take it apart and clean it up real good. (make sure you remember how to put it back together) It may not even look dirty "mine didn't" but lube stuff up and make sure it moves good. Put it back on and it should run just fine. Assuming that was the problem and not a vacuum line.
Old 05-13-2004, 04:56 PM
00tegra 00tegra is offline
it's probally just your fast idle
Old 05-13-2004, 09:11 PM
Hybrid1990crx's Avatar
Definetly sounds like vacuum to me. My DSM did that when I first got it and I just re-did all the lines and it ran fine. But that car is long gone now.
Old 05-14-2004, 02:06 AM
quickquarter quickquarter is offline
it is the iac (idle air control valve)
2000 Integra Type-R 13.3 @ 120mph
1989 Honda CRX Si 14.2 @ 110mph
Up at 5,280 feet above sea level all-motor!!!!!
Old 05-15-2004, 02:27 AM
streetrcr45's Avatar
streetrcr45 streetrcr45 is offline
happened to my car... turned out it was the throttle body, my car had crazy idle hops, from like 1500 up to 2300 and it consistantly did it, than it had little ones like 200rpm hops. hope you figure out the problem and get it fixed
DIE TRYIN
FORGIVE BUT NEVER FORGET
Old 06-06-2004, 10:42 PM
asiandeity asiandeity is offline
I had the same problem with my OBDI JDM GSR motor. Turns out it was my fast idle located underneath the throttle body. One of the part came loose inside so I took it apart and tightened it back up. Cost me $4 to repair. Needed a new throttle body gasket.
Old 06-07-2004, 01:45 AM
90gs's Avatar
90gs 90gs is offline
Send a message via ICQ to 90gs
its probably not your fast idle valve, i have the same problem and i bought a brand new fast idle valve and it didnt fix anything. its either your MAP sensor, your TPS (throttle positioning sensor), or your IAC.
TPS sensor = have to buy whole new throttle body ($700 from dealership )
Old 06-07-2004, 07:01 AM
UPDATE - it WAS the fast idle valve. I took it apart and noticed that the white plastic body inside had loosened up in the barrel. I screwed it back in and the car now idles a whole lot better. Thanks for the tips.
Old 06-08-2004, 12:58 PM
almxdupintegra almxdupintegra is offline
Where and how do you fix this?
FRIENDS DON'T LET FRIENDS DRIVE STOCK
