Old 05-10-2004, 05:34 PM
nicolai nicolai is offline
2000 cavakier stalling,driving me crazy
I have a 2000 cavalier with a 2.2 in it. It keeps stalling whenever i stop at red lights and sometimes when i put it into reverse. I have changed the fuel filter, air filter, oil, and spark plugs. I have also added fuel injector cleaner ( gummout ) to the tank twice.the car is not overheating or low on gas. It is not due to weather conditions.(does it in rain or shine, hot or cold). It has roughly 38,000 miles on it. I can also feel it hesitating (chugging) once in a while while driving.I have been puttting high octane in it lately with no change. After it stalls it will start right back up, only once or twice did it take me a few tries to get it to start. it does seem like it is not idling very well or slow.
Any help on this would be greatly appreciated. I hope i gave enough information for someone to give me a good guess what is going on here.
Nicolai
Old 05-12-2004, 05:07 AM
equalizr equalizr is offline
ive been having the same problems lately as well. any solutions?
Old 05-14-2004, 04:46 AM
bump
Old 05-14-2004, 10:33 AM
doormouse1058 doormouse1058 is offline
Send a message via AIM to doormouse1058
Re: 2000 cavakier stalling,driving me crazy
my car has been doin the same thing with all the same problems. Ive noticed a increse in my oil pressure, and sometimes it is off the gauge. Ive tryed just about everything to fix it but still, nothing. I wish i could help you but i can't figure it out myself. If anyone knows what could be causing this PLEASE HELPP!!!
Old 05-14-2004, 11:10 AM
skarkoc skarkoc is offline
mabey????
pcv valve...
Old 05-15-2004, 03:01 AM
well my car is a 2001 (i think or 2002)
anyways, i have the book that goes up to 2000, are the 2001 and 2002 any different?
in my book it says i have no PCV valve (that i can change)
Old 05-15-2004, 06:26 AM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
Nicolai
This may help
Engine Hestitates, Stalls, Will Not Start (Replace Modular Fuel Sender Strainer) #00-06-04-044 - (10/16/2000)
Engine Hesitates, Stalls and/or Will Not Start (Replace Modular Fuel Sender Strainer)
2000 Chevrolet Cavalier, Malibu
2000 Oldsmobile Alero
2000 Pontiac Grand Am, Sunfire
2000 Toyota Cavalier
Condition
Some customers may comment that the vehicle engine hesitates, stalls and/or will not start.
Cause
This condition may be caused by a restricted or plugged in-tank modular fuel sender strainer.
Correction
Replace the existing modular fuel sender strainer with a new strainer, P/N 88891094. To insure correct installation, follow the instruction sheet contained in the service kit. Also, refer to the service procedure found in the Engine Controls sub-section of the Service Manual.
Parts Information
Part Number
Description
88891094
Fuel Strainer Kit
Parts are currently available from GMSPO.
or this
Engine Stalls During Reverse or Drive Engagement
Checks Auxiliary Valve Body
Cause Missing or clogged TCC auxiliary valve body filter
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
Old 05-17-2004, 10:51 AM
VW/CHEVYGUY VW/CHEVYGUY is offline
Send a message via MSN to VW/CHEVYGUY
look a few pages back. I just went through this for four months with my 96 2.2 auto. Final solution was the neutral safety switch terminals were corroded. I replaced O2 sensor,TPS,IAC motor,crank sensor,ignition module,fuel pump, oil pressure switch.. Final repair was reapiring/cleaning the neutral safety switch terminals and the replacement TPS was bad as well. It would stall at a rest - stopped at a light or even idling in park after a few minutes. For the 3 days after the first replacement TPS, it actually started giving out at highway speeds. The "new" TPS was dead at idle until about 1/4 throttle before it registered any voltage.
