Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 05-10-2004, 05:18 PM
raven_240 raven_240 is offline
tech turbo quiestion
OK. Now I have a good idea on how to fined the right compressor for my engine by maping my engine's air requierments at any given boost on a compressor map. You can do this using one of two equations
First the esiast one to use is CFM = (L x RPM x VE x Pr)/5660
where L=liters of your engine, VE= your engins eficiancy usaly between 85-95% and Pr= pressure ration found by the equation Pr=(14.7+(boost you are running))/14.7.
this worked for maping my t25 turbo out on my 2.0 liter sr20det pritty acuratly at 10psi.
the other one you can use is EVF=(engineCID)/1728 * (rpm/2)
then take the evf, witch is in CMF, and convert it to lbs/min using this formula
N=(P*EVF*29)/(10.3*T)
Where N is the airflow in lb/min, P is the absolute pressure in psi, and T is the absolute ambient temperature in Rankin.
Finally, multiply N by the volumetric efficiency of your engine (VE). This compensates for the fact that upon every cycle of the engine, not all of the old air/fuel mix in the cylinders is forced out the exhaust. Thus there is a difference .
Firs question is wich method is more acurate, second anyone know how to match the turbine to your engine?
Anything can be fast its all about how much money you put in and most of all how much skill you bring.
